Home » Language IDEs » Java Development Tools (JDT) » Ant - "Copying resources to output folder"
Ant - "Copying resources to output folder" [message #44992] Fri, 30 May 2003 14:03 Go to next message
Originally posted by: Justin.studiox.net
Often (not always though) when I start an ant build, eclipse tries to
clean and copy resources to an output folder. The source tree I am
working with is rather large and this step is not needed as all the
build information is in build.xml and will be handled by ant. How I
handle this now is to just cancel the step and restart the build - then
it does not try to do this again until more files have been modified.
Is there any way to turn this off?
-Justin
justin at studiox dot net
Re: Ant - "Copying resources to output folder" [message #45159 is a reply to message #44992] Fri, 30 May 2003 14:31 Go to previous messageGo to next message
There is a global setting in the Debug preferences to control building if
required before launching.
Turn this off.
HTH
Darins
"Justin" <Justin@studiox.net> wrote in message
news:bb86dq$6u3$1@rogue.oti.com...
> Hello,
> -Justin
Re: Ant - "Copying resources to output folder" [message #45478 is a reply to message #45159] Fri, 30 May 2003 16:52 Go to previous message
Thanks - worked perfectly!
-Justin
> Turn this off.
> HTH
> Darins
>>Hello,
>>Thanks,
>>-Justin
Previous Topic:Java debugger doesn't start
Next Topic:setting up an EAR project in eclipse
Current Time: Sun Aug 31 17:32:55 EDT 2025
Powered by FUDForum. Page generated in 0.04112 seconds
