Home » Eclipse Projects » Mylyn » Can you remove "Unmatched Tasks"?
Can you remove "Unmatched Tasks"? [message #44968] |
Fri, 07 March 2008 03:31  |
I have a category of Mylyn tasks called "Unmatched Tasks" that I didn't
create. Presumbably they come from queries I once set up and then
discarded, or something. Can I get rid of them?
Re: Can you remove "Unmatched Tasks"? [message #45131 is a reply to message #45107] |
Sat, 08 March 2008 09:22   |
Mik, in the FAQ entries the term "Archive Category" is used with regard to filtering and as a
general category. AFAIK, the filtering is no longer supported/needed, and the category is now a
connector specific unmatched category.
Is that correct? Then, the FAQ should be updated.
Cheers, Jörg
On 03/08/08 01:29, Mik Kersten wrote:
> To get rid of tasks in the Unmatched container you can Delete them. I
> just updated the corresponding FAQ entry:
> http://wiki.eclipse.org/Mylyn_FAQ#Why_do_tasks_appear_in_the _Unmatched_container.3F
> Mik
> Mark Kirchner wrote:
>>> didn't create. Presumbably they come from queries I once set up and
>>> then discarded, or something. Can I get rid of them?
>> Well, as far as I know you can't get rid of the "unmatched" category
>> /permanently/, but you when you delete all its entries, the category
>> is automatically hidden.
>> It may reappear, though: As soon as a task is no longer matched by at
>> least one "regular" query it shows up in the "unmatched" category.
>> BTW: I'm talking about Mylyn 2.3, the behaviour might be different in
>> older versions.
>> HTH,
>> Mark
Re: Can you remove "Unmatched Tasks"? [message #45283 is a reply to message #45131] |
Tue, 11 March 2008 14:09   |
Originally posted by: rob.elves.eclipse.org
Jörg,
You are correct, the Archive is a thing of the past and has been
replaced with repository specific Unmatched containers. I've update the
FAQ terminology.
-Rob
> to filtering and as a general category. AFAIK, the filtering is no
> longer supported/needed, and the category is now a connector specific
> unmatched category.
> Cheers, Jörg
>> Mik
>>> Hi,
>>> older versions.
>>> HTH,
>>> Mark
Re: Can you remove "Unmatched Tasks"? [message #588376 is a reply to message #44968] |
Fri, 07 March 2008 05:59  |
/permanently/, but you when you delete all its entries, the category is
older versions.
HTH,
Mark
Re: Can you remove "Unmatched Tasks"? [message #588397 is a reply to message #45043] |
Fri, 07 March 2008 19:29  |
Mik
> older versions.
> HTH,
> Mark
Re: Can you remove "Unmatched Tasks"? [message #588401 is a reply to message #45107] |
Cheers, Jörg
> Mik
>> older versions.
>> HTH,
>> Mark
Re: Can you remove "Unmatched Tasks"? [message #588447 is a reply to message #45131] |
Jörg,
FAQ terminology.
-Rob
> unmatched category.
> Cheers, Jörg
>> Mik
>>> Hi,
>>> older versions.
>>> HTH,
>>> Mark
Current Time: Wed Jul 16 15:57:04 EDT 2025
Powered by FUDForum. Page generated in 0.10737 seconds
