copy and paste doesn't work after installing VE [message #44929] |
Tue, 29 June 2004 14:09  |
I have Eclipse 3.0 released with VE20040628 with all required GEF and EMF.
VE Editor works fine but I have one annoying side effect after
installing VE.
I cannot copy/cut and paste of my code anymore in my java editor once I
install VE.
Does anyone have same issue? How can I make Copy and Paste work?
There is nothing in Error log that relate to this issue.
Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #45024 is a reply to message #44998] |
Tue, 29 June 2004 16:37  |
Hello Rich,
It works now... I don't know if resetting regional setting or simply
restarting the system, my eclipse now behaves as it should be.
Sorry for the trouble.
Sang Uk Seong
Sang Uk Seong wrote:
> Rich Kulp wrote:
>> 1) What versions of Eclipse, VE, GEF, and EMF are you using?
> VE S20040628, EMF R200406280827 GEF 3.0
> Eclipse 3.0 SDK (20040625)
>> 2) What is your operating system?
> Windows XP
>> 3) What is your locale? Is it English?
> It is Korean (English Windows XP with English Regional and Korean
> non-Unicode Program Locale (In Advanced tab)
> (I will try to change back to English see if it works...)
>> It works fine on our Windows XP systems. No problem with cut and paste.
> I had same problem with RC2 with previous Stable builds as well like
> S2004622
> Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #593105 is a reply to message #44929] |
Tue, 29 June 2004 15:22  |
Rich
> Hello,
> installing VE.
> install VE.
> Sang Uk Seong
Thanks, Rich Kulp
Re: copy and paste doesn't work after installing VE [message #593122 is a reply to message #44956] |
Tue, 29 June 2004 16:26  |
Windows XP
S2004622
Sang Uk Seong
Re: copy and paste doesn't work after installing VE [message #593135 is a reply to message #44998] |
Hello Rich,
Sang Uk Seong
> Windows XP
> S2004622
> Sang Uk Seong
FUDForum. Page generated in 0.04096 seconds
