[Team] Eclipse spontaneously unable to connect to host [message #44910] |
Fri, 23 May 2003 01:05  |
WinXP, R2.1
I can ping our host, and all my settings for the "repository location"
are correct, but spontaneously, even after reboot, Eclipse refuses to
connect:
!SESSION May 23, 2003 00:50:14.935
java.fullversion=J2RE 1.4.0 IBM Windows 32 build cn140-20020902 (JIT
enabled: jitc)
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Ekleipsis/eclipse/
!ENTRY org.eclipse.team.cvs.core 4 4 May 23, 2003 00:50:14.935
!MESSAGE Cannot connect to host
anyone have any idea what weng wrong?
Paul
Re: [Team] Eclipse spontaneously unable to connect to host [message #45514 is a reply to message #44910] |
Fri, 23 May 2003 09:28   |
Originally posted by: Michael_Valenta.oti.com
I haven't seen a problem like this before. What connection method are
you using?
You can try the following to help narrow down where the problem may lie.
1) Check out a project from cvs using the command line client
2) Import the project into Eclipse
3) Perform a Team>Share Project to connect the project to the Eclipse
CVS client.
4) Perform an operation on the project (say Team>Update).
5) If the above fails, it could still be your password. In the CVS
Repositories view, select the repository location for the project you
imported and choose Properties from the context menu. Reenter your
password and click OK
6) Try the operation again
Did any of the above steps fail?
Paul T. Keyser wrote:
> WinXP, R2.1
> connect:
> enabled: jitc)
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Paul
Re: [Team] Eclipse spontaneously unable to connect to host [message #45723 is a reply to message #45514] |
Fri, 23 May 2003 10:12   |
connection method: pserver
turned out that rebooting our host server fixed the problem (I couldn't do
it, since it's in someone else's locked office). I suspect # 1 would have
failed; I had tried # 5, and that hadn't helped.
Paul K
> you using?
> CVS client.
> > WinXP, R2.1
> > connect:
> > enabled: jitc)
> > Thanks,
> > Paul
Re: [Team] Eclipse spontaneously unable to connect to host [message #52400 is a reply to message #51685] |
Wed, 28 May 2003 16:31  |
Michael,
> I have done some testing on this and have noticed that, at the times
> that Eclipse fails to connect to sourceforge, the command line client
> also fails. This indicates to me that it is a problem with sourceforge.
> My guess is that it is a server utilization problem. I will update th
> ebug report accordingly.
That's odd. I have found myself going back to using other clients when
eclipse fails on sourceforge or rather when sourceforge fails on eclipse.
Maybe you can contact sourceforge administrators about their specific
cvs setup and ask them for their opinion.
Many developers rely on sourceforge and it is in best interest to have
this resolved. That said I want to commend you guys on the best cvs
client out there. Your ideas about synchronize tool is a generation beyond
others. Please keep the bug update if you find out anything new about
this issue.
Best regards.
FUDForum. Page generated in 0.32917 seconds
