Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Vertical scroll bar for Text control
Vertical scroll bar for Text control [message #446296] |
Tue, 23 November 2004 10:31 |
Christian Hauser Messages: 189 Registered: July 2009 |
Hello everybody
I have a composite that contains a Text control. However, when the
composite is too small to display all the text I'd like to get a
vertical scroll bar.
I tried different things, but don't seem to get any closer to a solution.
I provided a test example below. I'd like to have the scroll bars
(actually a vertical scroll bar would be sufficient) next to the
composite and it should scroll through the text. Or can I have a text
control with scroll bars?
I put the composite into a shell, but in my application it will be
within another composite.
I'd be very happy if someone could enlighten me on how to scroll through
a text composite (that might even be disabled or at least read only) if
not all of the text can be read.
Thanks in advance for any help,
Christian
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.ScrollBar;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class ScrollTextExample {
Display display = new Display();
final Shell shell = new Shell(display);
GridLayout gridLayout = new GridLayout(1, true);
gridLayout.marginWidth = 0;
gridLayout.marginHeight = 0;
shell.setLayout(new GridLayout(1, true));
final Composite composite = new Composite(shell, SWT.V_SCROLL |
SWT.H_SCROLL);
composite.setLayout(gridLayout);
GridData gridData = new GridData(GridData.FILL, GridData.FILL,
true, true);
composite.setLayoutData(gridData);
final Text text = new Text(composite, SWT.MULTI | SWT.BORDER |
SWT.WRAP | SWT.READ_ONLY);
text.setText("The quick brown fox jumps over the lazy dog and I
struggle with SWT.");
gridData = new GridData(GridData.FILL, GridData.FILL, true, true);
text.setLayoutData(gridData);
final ScrollBar hBar = composite.getHorizontalBar();
hBar.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
Point location = text.getLocation();
location.x = -hBar.getSelection();
text.setLocation(location);
final ScrollBar vBar = composite.getVerticalBar();
vBar.addListener(SWT.Selection, new Listener() {
location.y = -vBar.getSelection();
composite.addListener(SWT.Resize, new Listener() {
Point size = text.getSize();
Rectangle rect = composite.getClientArea();
hBar.setMaximum(size.x);
vBar.setMaximum(size.y);
hBar.setThumb(Math.min(size.x, rect.width));
vBar.setThumb(Math.min(size.y, rect.height));
int hPage = size.x - rect.width;
int vPage = size.y - rect.height;
int hSelection = hBar.getSelection();
int vSelection = vBar.getSelection();
if (hSelection >= hPage) {
if (hPage <= 0)
hSelection = 0;
location.x = -hSelection;
if (vSelection >= vPage) {
if (vPage <= 0)
vSelection = 0;
location.y = -vSelection;
shell.setBounds(100, 100, 100, 80);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: Vertical scroll bar for Text control [message #446305 is a reply to message #446296] |
Tue, 23 November 2004 13:58 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
To get a vertical scrollbar on the Text widget, just create the Text widget
with the SWT.V_SCROLL style. The widget manages the proper scrolling
behaviour for you.
shell.setLayout(gridLayout);
final Text text = new Text(shell, SWT.MULTI | SWT.BORDER | SWT.WRAP
| SWT.READ_ONLY | SWT.V_SCROLL);
GridData gridData = new GridData(GridData.FILL, GridData.FILL, true,
true);
shell.open();
display.sleep();
display.dispose();
"Christian Hauser" <christian.hauser@dvbern.ch> wrote in message
news:cnv3ht$84s$1@www.eclipse.org...
> Hello everybody
> composite is too small to display all the text I'd like to get a vertical
> scroll bar.
> (actually a vertical scroll bar would be sufficient) next to the composite
> and it should scroll through the text. Or can I have a text control with
> scroll bars?
> I put the composite into a shell, but in my application it will be within
> another composite.
> I'd be very happy if someone could enlighten me on how to scroll through a
> text composite (that might even be disabled or at least read only) if not
> Christian
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> SWT.H_SCROLL);
> true);
> if (hPage <= 0)
> hSelection = 0;
> if (vPage <= 0)
> vSelection = 0;
> shell.open();
> display.sleep();
> display.dispose();
Current Time: Fri Apr 26 15:24:40 GMT 2024
Powered by FUDForum. Page generated in 0.03423 seconds
