Home » Archived » DSDP - Real-Time Software Components (RTSC) » RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes
RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes [message #3920] Sat, 13 June 2009 14:07 Go to next message
I'm starting to walk through lessons and examples for the RTSC Primer. But
the first example doesn't work on my Windows host.
Citation in http://rtsc.eclipse.org/docs-tip/RTSC_Module_Primer/Lesson_0 :
"Windows-hosted developers should surround «xdcroot» or «c6xtools» with
double-quotes "..." if these directory paths contain any spaces in their
names."
I did this and lesson 1 doesn't work. The output is:
"C:/Programme/Texas Instruments/xdctools_3_10_03"/xs xdc.tools.configuro
-c "C:/Programme/Texas Instruments/C6000 Code Generation Tools 6.1.10" -t
ti.targets.C64P -p ti.platforms.sim64Pxx -o cfgsite prog.cfg
Der Befehl ""C:/Programme/Texas Instruments/xdctools_3_10_03"" ist
entweder falsch geschrieben oder
konnte nicht gefunden werden.
gmake: *** [cfgsite/compiler.opt] Error 1
It look like the double-quotes are not in the right place. I did other
modifications in "common.mak": surround macros+extenstions with
double-quotes. This works.
Question: what will be best practice for solving the problem? And can this
configurations used on Linux hosts too?
Andi
--- common.mak ---
## -------- common makefile -------- ##
## -------- host-specific paths -------- ##
## MODIFY THESE PATHS PER YOUR
INSTALLATION
## WINDOWS HOST -- SURROUND THESE
PATHS WITH "" "" IF THEY CONTAIN SPACES
XDCROOT = C:/Programme/Texas Instruments/xdctools_3_10_03
C6XTOOLS = C:/Programme/Texas Instruments/C6000 Code Generation Tools
6.1.10
## -------- remove command -------- ##
## LINUX HOSTS -- REPLACE
$(XDCROOT)/bin/rm WITH rm
RMCMD = $(XDCROOT)/bin/rm
## --------build tools -------- ##
CONFIGURO = "$(XDCROOT)/xs" xdc.tools.configuro
LOADER = "$(XDCROOT)/xs" xdc.tools.loader
CC = "$(C6XTOOLS)/bin/cl6x" -q
## -------- build parameters -------- ##
CONFIG = cfgsite
TARGET = ti.targets.C64P
PLATFORM = ti.platforms.sim64Pxx
PROGNAME = prog
## -------- all-rule -------- ##
all : $(PROGNAME).out
## -------- config-rule -------- ##
$(CONFIG)/linker.cmd $(CONFIG)/compiler.opt : $(PROGNAME).cfg
$(CONFIGURO) -c "$(C6XTOOLS)" -t $(TARGET) -p $(PLATFORM) -o $(CONFIG)
$(PROGNAME).cfg
## -------- compile-rule -------- ##
$(PROGNAME).obj : $(PROGNAME).c $(CONFIG)/compiler.opt
$(CC) -@$(CONFIG)/compiler.opt -c $(PROGNAME).c
## -------- link-rule -------- ##
$(PROGNAME).out : $(PROGNAME).obj $(CONFIG)/linker.cmd
$(CC) -z -c $^ -o $(PROGNAME).out -l "$(C6XTOOLS)/lib/rts64plus.lib"
## -------- test-rule -------- ##
test : $(PROGNAME).out
$(LOADER) $(PROGNAME).out
## -------- clean-rule -------- ##
clean :
$(XDCROOT)/bin/rm -rf $(CONFIG) *.obj *.out
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes [message #3928 is a reply to message #3920] Sun, 14 June 2009 13:25 Go to previous messageGo to next message
Originally posted by: bob.biosbob.biz
i have to be honest with you.... i've seen so many issues with spaces in
pathnames that my best advice is: avoid them if possible!!!!
i'm not sure i understand what you did that eventually worked, but could
you send an example....
the text in the module primer was probably a little misleading, for
which we apologize....
Andreas Zoufal wrote:
> But the first example doesn't work on my Windows host.
> Citation in
> names."
> -t ti.targets.C64P -p ti.platforms.sim64Pxx -o cfgsite prog.cfg
> this configurations used on Linux hosts too?
> Andi
> --- common.mak ---
> INSTALLATION
> THESE PATHS WITH "" "" IF THEY CONTAIN SPACES XDCROOT =
> 6.1.10
> CONFIG = cfgsite
> PROGNAME = prog
> $(CONFIG) $(PROGNAME).cfg
> clean :
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes [message #3933 is a reply to message #3928] Mon, 15 June 2009 11:28 Go to previous messageGo to next message
I agree with you, avoiding spaces in path names would be the best
solution. Unfortunately, TI uses spaces in the setup default pathes of
their products, for example:
"C:\Programme\Texas Instruments\xdctools_3_10_03" on a german Windows XP
"C:\Program Files\Texas Instruments\xdctools_3_10_03" on an english
Windows XP
Following the hint at lesson 0, I modified common.mak:
XDCROOT = "C:/Programme/Texas Instruments/xdctools_3_10_03"
C6XTOOLS = "C:/Programme/Texas Instruments/C6000 Code Generation Tools
6.1.10"
Good idea, but it seem windows doesn't allow the concatenation of quoted
pathes with sub-pathes. Running lesson1/makefile comes up with this
application name:
This will not work. We need this command:
"C:/Programme/Texas Instruments/xdctools_3_10_03/xs"
You see what I mean? Other combined path names will be malformed, e.g.:
CONFIGURO = $(XDCROOT)/xs xdc.tools.configuro
LOADER = $(XDCROOT)/xs xdc.tools.loader
CC = $(C6XTOOLS)/bin/cl6x -q
...-l $(C6XTOOLS)/lib/rts64plus.lib
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes [message #3939 is a reply to message #3933] Mon, 15 June 2009 12:58 Go to previous messageGo to next message
another approach is to use the old DOS 8.3 name that corresponds to
filenames with spaces.... no quotes would then be needed....
> Windows XP
> 6.1.10"
> application name:
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes [message #3964 is a reply to message #3939] Tue, 16 June 2009 07:57 Go to previous messageGo to next message
This may be a workaround. But anyway, the hint to use double-quotes will
not work and should be removed.
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes - SOLUTION [message #4003 is a reply to message #3964] Tue, 16 June 2009 10:58 Go to previous messageGo to next message
Re: RTSC Module Primer / Lesson 0+1 Examples / Windows Double-Quotes - SOLUTION [message #4098 is a reply to message #4003] Tue, 16 June 2009 11:03 Go to previous message
Sorry, here is the solution. Don't do this - put the whole path into
double-quotes:
6.1.10"
But put every "part" which contanis spaces into double-quotes:
XDCROOT = C:/Programme/"Texas Instruments"/xdctools_3_10_03
C6XTOOLS = C:/Programme/"Texas Instruments"/"C6000 Code Generation Tools
6.1.10"
This works!
Question: will this work on Linux too? I'm not familiar enough with the
Linux file systems.
Andi
Previous Topic:How to access a siblings config params?
Next Topic:compilation error in "RTSC Module Primer" Lesson2
Current Time: Tue Jul 15 04:42:58 EDT 2025
Powered by FUDForum. Page generated in 0.10052 seconds
