Home » Eclipse Projects » Subversive » Refresh after SVN update too slow
Refresh after SVN update too slow [message #44886] Thu, 23 April 2009 11:49 Go to next message
Running latest 3.4 + CDT + Subversive.
When updating from SVN, it seems Subversive triggers a complete project
refresh. For our project this is painfully sloooowwww (way slower than
the actual SVN update itself) e.g 5 seconds for the SVN update then a
minute or so for the project refresh.
Are there any plans for improving this? E.g. by having Subversive be a
bit smarter about what gets refreshed?
Can Subversive even do that or are its hands tied by the Eclipse
platform in some way? Is it really a question for the platform guys?
I hope there is a solution ... I even tried Subclipse but found it too
buggy... :)
I've found a few references to this problem including this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266492
I'm running with the patch mentioned there but that doesn't (seem to...)
help the whole-project-refresh issue.
Jon
Re: Refresh after SVN update too slow [message #44959 is a reply to message #44886] Mon, 27 April 2009 00:08 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
I do not know what happens with CDT, but with M2E the behaviour you
describe is triggered by out-of-workspace resource changes (CDT uses
external compiler, right?). I've profiled the problem some time ago but
never had time to implement more efficient refresh algorithm.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259287
Igor
Jon Wilson wrote:
> buggy... :)
> Cheers,
> Jon
Re: Refresh after SVN update too slow [message #45000 is a reply to message #44959] Mon, 27 April 2009 11:45 Go to previous messageGo to next message
Thanks for the reply Igor.
I don't think this is due to out-of-workspace changes, it just happens
on each SVN update, even if I haven't run a build or done anything else
that would make under-the-hood changes.
The Progress window indicates Eclipse is performing a project refresh
and I'm guessing it is a full project refresh given how long it takes.
It would be great if it only refreshed the changed files.
In case it is relevant... our build is through a CDT Make Target that
just runs 'make' and the build by-products aren't under version control.
If there are any tests/analysis I can run that would help then let me know.
Jon
> Igor
> Jon Wilson wrote:
>> project refresh. For our project this is painfully sloooowwww (way
>> slower than the actual SVN update itself) e.g 5 seconds for the SVN
>> update then a minute or so for the project refresh.
>> a bit smarter about what gets refreshed?
>> buggy... :)
>> to...) help the whole-project-refresh issue.
>> Cheers,
>> Jon
Re: Refresh after SVN update too slow [message #45958 is a reply to message #45000] Tue, 05 May 2009 11:34 Go to previous message
There are already reported bugs about this problem, as Igor Fedorenko wrote,
for more details please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259287,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266492.
If you provide test cases for the problem I'd greatly appreciate you.
> I don't think this is due to out-of-workspace changes, it just happens on
> each SVN update, even if I haven't run a build or done anything else that
> The Progress window indicates Eclipse is performing a project refresh and
> I'm guessing it is a full project refresh given how long it takes. It
> In case it is relevant... our build is through a CDT Make Target that just
> know.
> Cheers,
> Jon
>> Regards,
>> Igor
>> Jon Wilson wrote:
>>> Hi,
>>> buggy... :)
>>> Cheers,
>>> Jon
Previous Topic:Merge revisions not working
Next Topic:Working copy of local repository
Current Time: Thu Jul 17 03:43:13 EDT 2025
Powered by FUDForum. Page generated in 0.03429 seconds
