Home » Eclipse Projects » GEF » Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example
Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example [message #44871] Fri, 22 November 2002 10:32 Go to next message
Originally posted by: sy_cheung2.yahoo.com
Could someone please explain to me what is the difference between
LogicDiagramFactory and LogicTemplateFactory? They both have methods to
create Half Adder and Full Adder.
And does LogicTemplateFactory relate to Cut-and-Paste support in GEF? From a
previous positing, a GEF developer said Cut-and-Paste support will be
provide thru Template.
Thanks.
Re: Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example [message #44914 is a reply to message #44871] Fri, 22 November 2002 10:54 Go to previous messageGo to next message
The LogicTemplateFactory is basically just a rework of the
LogicDiagramFactory so we can use it with the new drag and drop palette
while the LogicDiagramFactory was used with the palette entries that used
the CreationTool.
Eric
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:arlghg$mgj$1@rogue.oti.com...
a
> Thanks.
Re: Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example [message #44940 is a reply to message #44914] Fri, 22 November 2002 13:19 Go to previous messageGo to next message
Thanks Eric,
Is it possible to have 1 creationTool to support both Drag-and-Drop and the
old Select-and-Click way?
Thanks.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:arlhog$neq$1@rogue.oti.com...
> the CreationTool.
> Eric
> > Hi,
From
> a
> > Thanks.
Re: Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example [message #44967 is a reply to message #44940] Fri, 22 November 2002 13:46 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
Why would you want both? Most application use either one or the other.
news:arlq99$shm$1@rogue.oti.com...
> Thanks Eric,
the
> Thanks.
used
> > the CreationTool.
> > Eric
> > > Hi,
to
> From
> > a
> > > Thanks.
Previous Topic:moving figures within figures
Next Topic:GEF version in WSAD 5.0?
Current Time: Mon Sep 01 02:37:20 EDT 2025
Powered by FUDForum. Page generated in 0.07861 seconds
