Home » Eclipse Projects » Mylyn » Is mapping possible for task status
Is mapping possible for task status [message #44847] Thu, 06 March 2008 04:34 Go to next message
I have been using generic web connector for roundup issue tracker. I
could not manage to get status of a task. Is it possible to map strings
for a status. For example
"not-applied" and "applied" will be considered as "Done"
Burak
Re: Is mapping possible for task status [message #44878 is a reply to message #44847] Thu, 06 March 2008 06:28 Go to previous messageGo to next message
See bug 189788: [web connector] Allow more task properties to be set using fixed mappings
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=189788)
At the moment, there is a hard-coded list of strings mapped to "Complete". It seems to me that
extending this list or making it configurable is low priority at the moment.
Did you consider provide a wrapper CGI script around roundup-tracker which maps dedicated parts
to a Mylyn friendly format?
Cheers, Jörg
Re: Is mapping possible for task status [message #45064 is a reply to message #44878] Fri, 07 March 2008 09:09 Go to previous message
Thanks Jörg.
I have written a wrapper script to make it work but it would be much
better to have a configurable task statuses.
Burak
>> strings for a status. For example
> moment.
> Cheers, Jörg
Re: Is mapping possible for task status [message #588323 is a reply to message #44847] Thu, 06 March 2008 06:28 Go to previous message
Cheers, Jörg
Re: Is mapping possible for task status [message #588385 is a reply to message #44878] Fri, 07 March 2008 09:09 Go to previous message
Thanks Jörg.
Burak
> moment.
> Cheers, Jörg
Previous Topic:highlight elements in code editor
Next Topic:Can you remove "Unmatched Tasks"?
Current Time: Tue Jul 08 07:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.07532 seconds
