Home » Eclipse Projects » GEF » having problem with mouselistener...
having problem with mouselistener... [message #44840] Fri, 22 November 2002 08:59 Go to next message
hi all,
I have an edit part, which of course has a figure associated. I call
Figure.addMouseListener, and my method for public void
mouseDoubleClicked(MouseEvent me) is not called, only
mousePressed is called, i don't know why?
is this correct approach to add editpart as a listener to figure, if so why
it's not
fired?
thanx,
ozgur
Re: having problem with mouselistener... [message #45042 is a reply to message #44840] Fri, 22 November 2002 13:59 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
If you want a figure to receive mouse buttons, then the GEF Tool will NOT
receive it, and you will not be able to use a DragTracker from that figure.
The reason you don't receive double-click is that mouseDown comes first, and
the DragTracker says: "I'm handling the mouse starting now, until the User
releases the button". So your figure will not get the mouse down.
So, in a CircuitEditPart, the Scrollbars receive mouse buttons, and it is
impossible to drag the Circuit when clicking on the scrollbar. Is this what
you want?
"Ozgur Kurt" <ozgurkurt@hotmail.com> wrote in message
news:arlb2j$im3$1@rogue.oti.com...
> hi all,
why
> it's not
> fired?
> thanx,
> ozgur
Re: having problem with mouselistener... [message #45184 is a reply to message #45042] Mon, 25 November 2002 03:37 Go to previous messageGo to next message
thanx for answering,
what i want is, there is a component on the screen, and when user
double-clicks it will open the file that defines this component.
what i need is handling double-click event. and bad news is i need this bad.
this was a feature of previous version(that's running on swt with custom
controls), users used this and liked this verymuch. i don't want to tell
them to select it from popup...
thanx again,
ozgur
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:arlsl5$tob$1@rogue.oti.com...
figure.
and
what
> you want?
> > hi all,
> why
> > it's not
> > fired?
> > thanx,
> > ozgur
Re: having problem with mouselistener... [message #45448 is a reply to message #45184] Mon, 25 November 2002 12:15 Go to previous messageGo to next message
So do it in the DragTracker that get's returned from the EditPart, not in
the Figure.
news:arsni2$dev$1@rogue.oti.com...
bad.
> thanx again,
> ozgur
NOT
> figure.
> and
User
is
> what
> > you want?
> > > hi all,
so
> > why
> > > it's not
> > > fired?
> > > thanx,
> > > ozgur
Re: having problem with mouselistener... [message #45835 is a reply to message #45448] Tue, 26 November 2002 05:44 Go to previous message
thank you, that worked
Previous Topic:Viewport strange behaviour
Next Topic:Container Highlight edit policy
Current Time: Sat Aug 30 23:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.04260 seconds
