Home » Archived » XML Schema Definition (XSD) » building XSDComplexTypeDefinition programmatically
building XSDComplexTypeDefinition programmatically [message #44838] Wed, 19 May 2004 10:41 Go to next message
Originally posted by: hoe.zurich.ibm.com
I've written some code to build an XSDComplexTypeDefinition from scratch
by calling to XSDFactory, setting a name, content, etc.
Do I also have to build a DOM representation and pass it into
setElement, or is this done somewhere automatically?
The issue is that my type seems to work fine for current purposes, but
that its element remains null even after a call to updateElement. Since
the XSDComplexTypeDefinition knows its name, etc., I would assume/hope
that it can build its DOM representation by itself.
Thanks for your help,
Christian
Re: building XSDComplexTypeDefinition programmatically [message #44866 is a reply to message #44838] Wed, 19 May 2004 11:49 Go to previous messageGo to next message
Christian,
No, the DOM can be created for you, but your complex type needs to be in an
XSDSchema in order to be able to that.
> Christian
Re: building XSDComplexTypeDefinition programmatically [message #45132 is a reply to message #44866] Fri, 21 May 2004 05:19 Go to previous message
Ed,
Yes, this made the difference. Thx much.
Re: building XSDComplexTypeDefinition programmatically [message #587232 is a reply to message #44838] Wed, 19 May 2004 11:49 Go to previous message
Christian,
> Christian
Re: building XSDComplexTypeDefinition programmatically [message #587330 is a reply to message #44866] Fri, 21 May 2004 05:19 Go to previous message
Ed,
Previous Topic:building XSDComplexTypeDefinition programmatically
Next Topic:A question about walkers/visitors
Current Time: Sun Aug 31 12:43:31 EDT 2025
Powered by FUDForum. Page generated in 0.08760 seconds
