Home » Eclipse Projects » Mylyn » highlight elements in code editor
highlight elements in code editor [message #44817] Wed, 05 March 2008 04:08 Go to next message
Originally posted by: xxx.xxx.no
When an element in my code editor becomes interesting enough, it is
assigned a landmark and that element in the code is highlighted.
Unfortunately, the hightlight color scheme does not work well with my java
editor's colour settings. I cannot see the text hightlighted because they
are the same colour.
I have tried changing every colour setting under preferences but I cannot
change the highlight colour. This is not a problem with mylyn deactivated.
Question: Is it possible to change the highlight colour and how?
thanks Neil
Re: highlight elements in code editor [message #44942 is a reply to message #44817] Fri, 07 March 2008 00:23 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Hi Neil,
We don't set a higlight color for landmarks by default since there is a
considerable amount of coloring in the Java editor already. However,
you can configure the background color for landmarks via Window ->
Preferences -> General -> Editors -> Text Editors -> Annotations.
Mik
> java editor's colour settings. I cannot see the text hightlighted
> because they are the same colour.
> cannot change the highlight colour. This is not a problem with mylyn
> deactivated.
> thanks Neil
Re: highlight elements in code editor [message #44990 is a reply to message #44942] Fri, 07 March 2008 05:23 Go to previous messageGo to next message
Originally posted by: neil.harrison.xxx.com
Many thanks Mik
Great. That fixed that.
It was one of those preferences I had not thought about clicking in.
Neil
Re: highlight elements in code editor [message #45080 is a reply to message #44990] Fri, 07 March 2008 19:25 Go to previous messageGo to next message
Would be great if you could add an entry to the FAQ to help others with
a similar use case.
http://wiki.eclipse.org/index.php/Mylyn_FAQ
Mik
Neil wrote:
> Many thanks Mik
> Great. That fixed that. It was one of those preferences I had not
> Neil
Re: highlight elements in code editor [message #45607 is a reply to message #44942] Thu, 13 March 2008 18:37 Go to previous messageGo to next message
Originally posted by: sean.stilogic.com
I have a corollary question: how can I change the color of the Landmark
foreground? I use high-contrast black for my screen colors and the
Landmarks look like they are bold and very close to black or actually
black, which makes them very hard for me to see. I had already found my
way to the background color setting. I looked in the FAQ but I didn't see
either question covered.
I'll be more than happy to add the previous solution and if it exists, the
solution to my question. Has anyone else already added the previous
solution to the FAQ and I just missed it?
Thanks for any help -
Sean
Re: highlight elements in code editor [message #47073 is a reply to message #45607] Tue, 15 April 2008 12:16 Go to previous message
Sean,
I added a short section on how to do this to the User Guide. Please
feel free to expand on it. Note that to do this you would want to
change the Java Editor font color.
http://wiki.eclipse.org/Mylyn_User_Guide#UI_Settings
Mik
> see either question covered.
> the solution to my question. Has anyone else already added the previous
> Sean
Re: highlight elements in code editor [message #588347 is a reply to message #44817] Fri, 07 March 2008 00:23 Go to previous message
Hi Neil,
Mik
> deactivated.
> thanks Neil
Re: highlight elements in code editor [message #588364 is a reply to message #44942] Fri, 07 March 2008 05:23 Go to previous message
Many thanks Mik
Neil
Re: highlight elements in code editor [message #588390 is a reply to message #44990] Fri, 07 March 2008 19:25 Go to previous message
a similar use case.
Mik
Neil wrote:
> Many thanks Mik
> Neil
Re: highlight elements in code editor [message #588554 is a reply to message #44942] Thu, 13 March 2008 18:37 Go to previous message
Sean
Re: highlight elements in code editor [message #589078 is a reply to message #45607] Tue, 15 April 2008 12:16 Go to previous message
Sean,
Mik
> Sean
Previous Topic:Update problems with Mylyn Bridge: PDE, CVS and Ant
Next Topic:Is mapping possible for task status
Current Time: Sun Aug 31 02:30:47 EDT 2025
Powered by FUDForum. Page generated in 0.04647 seconds
