Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table row heigth with GridLayout
Table row heigth with GridLayout [message #445393] |
Thu, 04 November 2004 21:37 |
jmi Messages: 84 Registered: July 2009 |
Member |
With the code below, i have 2 tables. If you run the code, you'll see that
the result table is about 3 rows heigth. I would like to limit it to 1 row
because it is a result table.
Thanks for your help
JMi
CODE
import java.text.Collator;
import java.util.Locale;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class _Test1Table extends Composite {
private Table _detailsTable = null;
private Table _resultTable = null;
public _Test1Table(final Composite argParent, final int argStyle) {
this(argParent, argStyle, 0, 0, 3);
public _Test1Table(final Composite argParent, final int argStyle,
final int argMarginHeigth, final int argMarginWidth,
final int argVerticalSpacing) {
super(argParent, SWT.NONE);
createContents(argStyle, argMarginHeigth, argMarginWidth,
argVerticalSpacing);
protected void createContents(final int argStyle, final int
argMarginHeigth,
final int argMarginWidth, final int argVerticalSpacing) {
try {
GridLayout layout = new GridLayout();
layout.numColumns = 1;
layout.marginHeight = argMarginHeigth;
layout.marginWidth = argMarginWidth;
layout.verticalSpacing = argVerticalSpacing;
setLayout(layout);
// Main Table
_detailsTable = new Table(this, argStyle);
_detailsTable.setHeaderVisible(true);
_detailsTable.setLinesVisible(true);
TableColumn column1 = new TableColumn(_detailsTable, SWT.NONE);
column1.setText("Column 1");
TableColumn column2 = new TableColumn(_detailsTable, SWT.NONE);
column2.setText("Column 2");
column2.setAlignment(SWT.RIGHT);
TableItem item = new TableItem(_detailsTable, SWT.NONE);
item.setText(new String[] { "a", "3" });
item.setText(new String[] { "b", "2" });
item.setText(new String[] { "c", "1" });
// column1.pack();
// column2.pack();
column1.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
// sort column 1
TableItem[] items = _detailsTable.getItems();
Collator collator = Collator.getInstance(Locale
.getDefault());
for (int i = 1; i < items.length; i++) {
String value1 = items[i].getText(0);
for (int j = 0; j < i; j++) {
String value2 = items[j].getText(0);
if (collator.compare(value1, value2) < 0) {
String[] values = { items[i].getText(0),
items[i].getText(1) };
items[i].dispose();
SWT.NONE, j);
item.setText(values);
break;
column2.addListener(SWT.Selection, new Listener() {
// sort column 2
.getDefault());
String value1 = items[i].getText(1);
String value2 = items[j].getText(1);
items[i].dispose();
SWT.NONE, j);
break;
// _detailsTable position
GridData data = new GridData();
data.horizontalAlignment = GridData.FILL;
data.verticalAlignment = GridData.FILL;
data.grabExcessHorizontalSpace = true;
data.grabExcessVerticalSpace = true;
_detailsTable.setLayoutData(data);
// Main Table
_resultTable = new Table(this, argStyle);
_resultTable.setHeaderVisible(false);
_resultTable.setLinesVisible(true);
TableColumn col1 = new TableColumn(_resultTable, SWT.NONE);
TableColumn col2 = new TableColumn(_resultTable, SWT.NONE);
col2.setAlignment(SWT.RIGHT);
TableItem item2 = new TableItem(_resultTable, SWT.NONE);
item2.setText(new String[] { "a", "3" });
col1.pack();
col2.pack();
// _resultTable position
//_resultTable.setSize(10, 10);
_resultTable.setLayoutData(data);
addColumnResizeListener(_detailsTable, _resultTable);
column1.pack();
column2.pack();
} catch (final Exception argEx) {
System.out.println(argEx.getMessage());
private void addColumnResizeListener(final Table argDetailsTable,
final Table argResultTable) {
TableColumn detailsColumn = null;
final int colCount = argDetailsTable.getColumnCount();
for (int i = 0; i < colCount; i++) {
detailsColumn = argDetailsTable.getColumn(i);
final int colNum = i;
detailsColumn.addListener(SWT.Resize, new Listener() {
if (argResultTable == null)
return;
argResultTable.getColumn(colNum).setWidth(
((TableColumn) e.widget).getWidth());
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
_Test1Table test = new _Test1Table(shell, SWT.BORDER);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: Table row heigth with GridLayout [message #445424 is a reply to message #445393] |
Fri, 05 November 2004 12:57 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
You need to set the data.heightHint to something like:
data.heightHint = Math.max (0, _resultTable.getItemHeight() -
_resultTable.computeTrim(0, 0, 0, 0).height +
2*_resultTable.getBorderWidth() + 2*_resultTable.getGridLineWidth());
"JM Delsaux" <JMDelsaux@skynet.be> wrote in message
news:cme7eb$ofn$1@eclipse.org...
> that the result table is about 3 rows heigth. I would like to limit it to
> 1 row because it is a result table.
> JMi
> CODE
> import org.eclipse.swt.widgets.Display;
> argMarginHeigth,
> try {
> setLayout(layout);
> // Main Table
> // column1.pack();
> // column2.pack();
> // sort column 1
> .getDefault());
> items[i].dispose();
> SWT.NONE, j);
> break;
> // sort column 2
> .getDefault());
> items[i].dispose();
> SWT.NONE, j);
> break;
> // Main Table
> col1.pack();
> col2.pack();
> column1.pack();
> column2.pack();
> return;
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
Re: Table row heigth with GridLayout [message #445445 is a reply to message #445424] |
Fri, 05 November 2004 20:19 |
Member |
Thanks Veronica, it runs :-))
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cmfthu$coi$2@eclipse.org...
>> to 1 row because it is a result table.
>> JMi
>> CODE
>> argMarginHeigth,
>> try {
>> setLayout(layout);
>> // Main Table
>> SWT.NONE);
>> SWT.NONE);
>> // column1.pack();
>> // column2.pack();
>> // sort column 1
>> .getDefault());
>> items[i].dispose();
>> SWT.NONE, j);
>> break;
>> // sort column 2
>> .getDefault());
>> items[i].dispose();
>> SWT.NONE, j);
>> break;
>> // Main Table
>> col1.pack();
>> col2.pack();
>> column1.pack();
>> column2.pack();
>> return;
>> shell.open();
>> display.sleep();
>> display.dispose();
Current Time: Sun Sep 22 12:43:21 GMT 2024
Powered by FUDForum. Page generated in 0.03210 seconds
