Home » Archived » BIRT » How do I limit the data set to a particular schema for Oracle JDBC connection?
How do I limit the data set to a particular schema for Oracle JDBC connection? [message #44804] Thu, 09 June 2005 21:42 Go to next message
When I define a data set on Oracle JDBC data source, I get an error popup
that "only 500 items can be viewed in the available list. There are more
than 500 items in the data source. Please specify a filter to search for
specific items." The data set Available Items list shows multiple schemas
and their associated tables. How do I limit the data set to a particular
schema?
Also, what is the format of the Filter field on the Query tab?
Re: How do I limit the data set to a particular schema for Oracle JDBC connection? [message #45825 is a reply to message #44804] Tue, 14 June 2005 14:41 Go to previous message
There is currently no way to limit the table list to within one or more
schemas. This does sounds like a good thing to have though. I suggest that
you file an enhancement request in Bugzilla if you'd like BIRT engineers to
look into adding this.
The Filter field in the Query Editor's table list accepts a SQL pattern
matching string. Only tables (in all schema) with names matching this
pattern will be listed. The pattern format is DB specific. For example, in
MS Server Server, % matches any substring while _ matches any single
character. Check the Oracle documentation to see what works there.
Gary Xue
BIRT Committer
"Bill Brooks" <billbr@genesyslab.com> wrote in message
news:1d375bb9d7eb5fef86fded17f514215c$1@www.eclipse.org...
> schema?
Previous Topic:Changing Property Edit Window
Next Topic:Getting database information from a datasource
Current Time: Wed Jul 16 12:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.04519 seconds
