Home » Eclipse Projects » Equinox » Invalid Bundle Activator all of a sudden!?
Invalid Bundle Activator all of a sudden!? [message #44803] Thu, 22 July 2004 11:06 Go to next message
Originally posted by: mark.melvin.dspfactory.com
I have just built a new drop of my platform and plugins to find that
none of my classes can be instantiated. I swear this worked yesterday
before I went home!
Everything runs fine in a runtime workbench, but when I create a new
branded platform with my plugins - nothign works. All I have done since
then is script the build, and manually bump all the revision numbers up
from 0.0.1 to 0.0.2. UI'm thinking this version change is what
triggered it but I could be wrong....
This is the start of my stack trace:
!SESSION Jul 22, 2004 10:56:49.786
eclipse.buildId=I200406251208
java.version=1.4.2_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
!ENTRY org.eclipse.osgi Jul 22, 2004 10:56:49.786
!MESSAGE An error occured while automatically activating bundle
com.mycorp.plugin.ui (5).!STACK 0
org.osgi.framework.BundleException: The activator
com.mycorp.plugin.ui.UIPlugin for bundle com.mycorp.plugin.ui is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:158)
All of my plugins are OSGI style and have the following line in the
MANIFEST.MF:
Bundle-Activator: com.mycorp.plugin.ui.UIPlugin
Basically the name of the main plugin class for each plugin I have. The
above line is from my com.mycorp.plugin.ui plugin. This has always
worked. Do I even need this entry, and who put it in there?
Any help would be greatly appreciated.
Mark.
Re: Invalid Bundle Activator all of a sudden!? [message #44833 is a reply to message #44803] Thu, 22 July 2004 11:28 Go to previous messageGo to next message
I just manually exported my features and unzipped them into a runtime
platform everything works fine. Something is different between the
automated and manual builds.
Doing a diff of the directories, everything looks fine. The class files
in the .jars are all different - but that is expected. I did however
find that there were some class files NOT in one of the automated
build's .jar file that were present in the manual build. They were:
com.mycorp.ui_0.0.2\ui\com\mycorp\internal\ui\wizards\tools\ ConvertProjectsPage$1.class
com.mycorp.ui_0.0.2\ui\com\mycorp\internal\ui\wizards\tools\ ConvertProjectsPage$2.class
com.mycorp.ui_0.0.2\ui\com\mycorp\internal\ui\wizards\NewPro jectWizard$1.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$1.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$10.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$11.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$2.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$3.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$4.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$5.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$6.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$7.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$8.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\preferences\SourceEdito rPreferencePage$9.class
com.mycorp.ui_0.0.2\ui\com\mycorp\ui\UIPlugin$1.class
What are all these class files with '$' in them?
Mark.
Mark Melvin wrote:
> before I went home!
> at
> MANIFEST.MF:
> Mark.
Re: Invalid Bundle Activator all of a sudden!? [message #44867 is a reply to message #44833] Thu, 22 July 2004 12:09 Go to previous messageGo to next message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
Those are anonymous inner classes.
Re: Invalid Bundle Activator all of a sudden!? [message #44918 is a reply to message #44867] Thu, 22 July 2004 13:07 Go to previous messageGo to next message
Aha. Thanks. Weird that they are missing from the automated build.
<sigh> I was having such a productive week, too....
Mark.
Re: Invalid Bundle Activator all of a sudden!? [SOLVED] [message #44939 is a reply to message #44833] Thu, 22 July 2004 13:36 Go to previous messageGo to next message
Well, I finally figured this out. There were a couple things combined
that threw me for a loop.
Basically - the Java compile on my automated build was failing, but the
"javacFailOnError" was not set to true - so the build ripped throuhg,
reporting it succeeded, but I only had a partial plugin. Actually, it
was supposed to be set, but my build.properties is based on an OLD
template from 3.0RC1 or M9, and the variable is all lower-case so it
wasn't actually setting the *correct* variable, thus never stopped on
failure.
ANYWAY - I fixed that, then the automated build stopped mid-way because
it couldn't build my plugin. This boiled down to the fact that I was
building 3 different features, each containing various plugins, but I
typed them into the "allElements" target in the wrong order, not
realizing that the dependencies were not automatically figured out at
build time.
So, I have PluginA, PluginB, and PluginC - where PluginC *requires*
PluginB. I had entered them into "allElements" as:
PluginA
PluginC (requires PluginB)
PluginB
Which generated about 400 compile errors in PluginC because most of it's
classes were missing (these classes residing in PluginB). So, simply
rearranging "allElements" to be:
PluginA
PluginB
...allowed my build to complete successfully and I now have a working
platform. I am a happy camper once again. Whew!
Mark.
> Mark.
> Mark Melvin wrote:
>> before I went home!
>> since then is script the build, and manually bump all the revision
>> numbers up from 0.0.1 to 0.0.2. UI'm thinking this version change is
>> what triggered it but I could be wrong....
>> invalid at
>> MANIFEST.MF:
>> The above line is from my com.mycorp.plugin.ui plugin. This has
>> always worked. Do I even need this entry, and who put it in there?
>> Mark.
Re: Invalid Bundle Activator all of a sudden!? [SOLVED] [message #44966 is a reply to message #44833] Thu, 22 July 2004 13:38 Go to previous messageGo to next message
failure.
build time.
PluginA
PluginB
PluginA
PluginB
Mark.
> Mark.
> Mark Melvin wrote:
>> before I went home!
>> invalid at
>> MANIFEST.MF:
>> Mark.
update.configurator logging errors on restart after installing dynamic plugins [message #45097 is a reply to message #44803] Wed, 28 July 2004 13:16 Go to previous messageGo to next message
Originally posted by: nalinig.ibm.us
My Eclipse version is 3.0 M9. I have a plugin A that dynamically installs
and starts plugin B from an install URL of the form
reference:file:/c:/eclipse/plugins/B_1.0.0/ using its bundleContext. The
plugin B activates successfully; the problem occurs after Eclipse is shut
down and restarted. There is an error logged by
org.eclipse.update.configurator that says
"Could not install bundle /c:/eclipse/plugins/B_1.0.0/ Bundle "B" version
"1.0.0" has already been installed from:
reference:file:/c:/eclipse/plugins/B_1.0.0/"
and there is no stack trace. The bundle B itself resolves fine, except
for this error message. I don't see this error if a plugin project starts
plugin B in a target workbench.
Why does the update.configurator try to install again from
/c:/eclipse/plugins/B_1.0.0/, who installs the bundle B the first time on
startup? Is there any way of avoiding this message in the error log?
Thanks for any help,
Nalini.
Re: update.configurator logging errors on restart after installing dynamic plugins [message #45129 is a reply to message #45097] Wed, 28 July 2004 15:01 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
Try using the Eclipse 3.0 final release, instead of a milestone build.
Some things (like the bundle location and error messages in the
configurator) have changed for the better.
"Nalini Ganapati" <nalinig@ibm.us> wrote in message
news:ce8n24$p7d$1@eclipse.org...
> Nalini.
Re: update.configurator logging errors on restart after installing dynamic plugins [message #45160 is a reply to message #45129] Wed, 28 July 2004 16:10 Go to previous messageGo to next message
Actually, I have the final release version of eclipse and can reproduce the
problem there too.
Nalini.
"dorian birsan" <dorian@birsan.net> wrote in message
news:ce8t38$3lc$1@eclipse.org...
installs
The
shut
version
starts
on
> > Nalini.
Re: Invalid Bundle Activator all of a sudden!? [SOLVED] [message #45190 is a reply to message #44939] Mon, 02 August 2004 10:14 Go to previous messageGo to next message
Put them into a feature and you don't have to worry about the right compile
order.
Cu, Gunnar
Re: Invalid Bundle Activator all of a sudden!? [SOLVED] [message #45220 is a reply to message #45190] Tue, 03 August 2004 09:46 Go to previous message
> order.
Thanks, Gunnar. Actually, I mis-typed that...they are all features (not
plugins). The proper thing for me to do is not build 3 features in one
build script - rather break it down into a build script pre feature like
the Eclipse build does. I'm working on that...
Mark.
Previous Topic:SWT/Plugin Book
Next Topic:Advanced Service Concept
Current Time: Sun Aug 31 09:04:04 EDT 2025
Powered by FUDForum. Page generated in 0.04290 seconds
