Home » Eclipse Projects » DTP » SQL Completion in DTP 1.6RC1
SQL Completion in DTP 1.6RC1 [message #44798] Mon, 26 May 2008 15:39 Go to next message
Originally posted by: sschaub.NOSPAM.gmail.com
Eclipse 3.3.2 on XP SP2 with DTP 1.6.0 RC1 and DB2 8.1
I am having some limited success with SQL completion in the SQL editor.
However, I am hoping for more, and wondering if the tool is functioning as
designed.
In the following query:
SELECT *
FROM AA.BBBB
... when I type this much
SELECT *
FROM AA.^
(^ indicates cursor location) I get a list of table names in the AA
schema. That's nice. However, if I just type
SELECT *
FROM ^
and request completion, I don't get a list of schema names or tables. Is
there a way to request a list of schema names? Even better, I would like
to see a list of tables in the current schema. But I don't see a way to
set a current schema for the editor.
Regarding column completion, when I type the following:
SELECT AA.BBBB.^
FROM AA.BBBB
and press Ctrl+Space at the ^ I get a list of column names in table BBBB.
However, when I request completion at the following location:
SELECT ^
FROM AA.BBBB
I get nothing. I would expect to see a list of columns from the tables in
the FROM clause - ?
By the way, I love the simplified connection profile creation in 1.6. A
vast improvement over earlier versions.
Re: SQL Completion in DTP 1.6RC1 [message #44988 is a reply to message #44798] Thu, 05 June 2008 17:17 Go to previous message
Originally posted by: sschaub.nowhere.net
Stephen Schaub wrote:
I spent some time browsing the source code and think I found some answers
to my own questions. I've documented what I think; corrections are welcome.
> designed.
> SELECT *
> FROM AA.^
> SELECT *
> FROM ^
In this scenario, the current DTP code tries to find a list of tables in a
default schema. The default schema is the schema whose name matches the
database connection login name. Since in my case there were no tables in
the default schema, nothing appeared.
I don't think there's a way to do this. I plan to check to see if there's
a feature request for this.
> SELECT AA.BBBB.^
> FROM AA.BBBB
> SELECT ^
> FROM AA.BBBB
> I get nothing.
It appears that the code completion engine does not take into account the
entire query when computing proposals. It attempts to parse the query to
the point where the cursor is located, and does not consider the remainder
of the statement. It's not designed to present a list of column names in
this scenario, and I don't think it can handle table aliases, either. Too
bad...
Re: SQL Completion in DTP 1.6RC1 [message #591295 is a reply to message #44798] Thu, 05 June 2008 17:17 Go to previous message
> designed.
> SELECT *
> FROM AA.^
> SELECT *
> FROM ^
> SELECT AA.BBBB.^
> FROM AA.BBBB
> SELECT ^
> FROM AA.BBBB
> I get nothing.
bad...
Previous Topic:Oracle
Next Topic:ecore ODA - dependencies for driver?
Current Time: Sun Aug 31 09:52:55 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
