Updating The Outline View [message #44787] |
Fri, 30 May 2003 10:42  |
Originally posted by: Danny.Collins.libertymutual.com
I am working on a plugin that alters the source file for a java class.
Inserting methods, reorganizing methods and fields, etc. I am having
trouble getting the Outline View to sync up with the actual source.
Especially when reordering the methods.
Thank you,
Danny
Re: Updating The Outline View [message #47283 is a reply to message #47008] |
Tue, 03 June 2003 08:53   |
That looks ok. Can you try to only add a method and see if this works.
Could be that a move does not generate a delta (what would be a bug)
Note that the outliner updates in a background thread, so there should
be no need to call reconcile to update the viewer.
Danny Collins wrote:
> Adam Kiezun wrote:
>>the outline works on working copies
>>if you modify java files, then you will need to reconcile the working copy
> with the file
>>try calling IWorkingCopy::reconcile()
>>a.
>>eclipse.org
> I tried that didn't seem to work, but I may not have the 'correct' working
> copy,
> Here is a snippet, the editor is gotten because I am an editor context
> menu item.
> ICompilationUnit icu =
> JavaUI.getWorkingCopyManager().getWorkingCopy(editor.getEdit orInput());
> // manipulate the compilation unit
> icu.reconcile(true,null);
> // this doesn't seem to update the outline view, but the outline still
> works, so if I move a method from the top to the bottom of the source, the
> outline stays the same but it will go to the correct place in the source
> if double clicked.
> Thansk for the help!
> Danny
Re: Updating The Outline View [message #49536 is a reply to message #47283] |
Wed, 04 June 2003 21:38  |
Originally posted by: danny.collins.libertymutual.com
OK, tried that, added a new method. It showed up in the Outline view, but
when I reorganized the rest of the source the outline view didn't change.
Although I am using eclispe 2.0 not 2.1 .
The only thing that seems to catch the outline up to the current source is
closing and reopening the file.
TIA.
> > with the file
> >>a.
> >>eclipse.org
> > copy,
> > menu item.
> > if double clicked.
> > Danny
FUDForum. Page generated in 0.08740 seconds
