Home » Archived » EPF » epf search ?
epf search ? [message #44778] Mon, 22 October 2007 05:47 Go to next message
I published a simple method to a .war file
deployed it (to weblogic 8.1)
website OK
but search doesn't give any results and I get the following stacktrace :
LD> searchString: group
convert group -> group
LD> _indexPath: null
LD> _currentSearchString: group
LD> unicodes: group
LD> analyzerName: null
LD> _hits: null
org.eclipse.epf.web.servlet.SearchServlet.runQuery(Ljava.lan g.String;
)Z(SearchServlet.java:206)
org.eclipse.epf.web.servlet.SearchServlet.runSearch(Ljava.la ng.String
;)Ljava.lang.String;(SearchServlet.java:174)
org.eclipse.epf.web.servlet.SearchServlet.doGet(Ljavax.servl et.http.H
ttpServletRequest;Ljavax.servlet.http.HttpServletResponse;)V (SearchServlet.java:
129)
javax.servlet.http.HttpServlet.service(Ljavax.servlet.http.H ttpServle
tRequest;Ljavax.servlet.http.HttpServletResponse;)V(HttpServ let.java:740)
javax.servlet.http.HttpServlet.service(Ljavax.servlet.Servle tRequest;
Ljavax.servlet.ServletResponse;)V(HttpServlet.java:853)
weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run
()Ljava.lang.Object;(ServletStubImpl.java:1006)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Ljav ax.servle
t.ServletRequest;Ljavax.servlet.ServletResponse;Lweblogic.se rvlet.internal.Filte
rChainImpl;)V(ServletStubImpl.java:419)
t.ServletRequest;Ljavax.servlet.ServletResponse;)V(ServletSt ubImpl.java:315)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionActio
n.run()Ljava.lang.Object;(WebAppServletContext.java:6718)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Lwe blogic.se
curity.subject.AbstractSubject;Ljava.security.PrivilegedActi on;)Ljava.lang.Objec
t;(AuthenticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(Lweblogic.se curity.ac
l.internal.AuthenticatedSubject;Lweblogic.security.acl.inter nal.AuthenticatedSub
ject;Ljava.security.PrivilegedAction;)Ljava.lang.Object;(Sec urityManager.java:12
1)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (Lweblogi
c.servlet.internal.ServletRequestImpl;Lweblogic.servlet.inte rnal.ServletResponse
Impl;)V(WebAppServletContext.java:3764)
weblogic.servlet.internal.ServletRequestImpl.execute(Lweblog ic.kernel
..ExecuteThread;)V(ServletRequestImpl.java:2644)
weblogic.kernel.ExecuteThread.execute(Lweblogic.kernel.Execu teRequest
;)V(ExecuteThread.java:219)
at weblogic.kernel.ExecuteThread.run()V(ExecuteThread.java:178)
java.lang.Thread.startThreadFromVM(Ljava.lang.Thread;)V(Unkn own Sourc
e)
Re: epf search ? [message #44877 is a reply to message #44778] Tue, 23 October 2007 15:27 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
From log
it looks like
_indexPath: null means that no index is available.
analyzerName is the name of analyzer used for generating index which is
null.
Can you try the following and see whether any of this makes a difference ?
1. check the deployed web app's search dir has the right files
2. try deploying it on Tomcat,
3. try OpenUP on Tomcat,
4. try OpenUP on WebLogic.
Shilpa
Re: epf search ? [message #44927 is a reply to message #44877] Fri, 26 October 2007 03:11 Go to previous messageGo to next message
Shilpa
- Deployed OpenUP to Weblogic - same error
the search dir contains the following :
dir : images
contains a lot of gifs
dir : index
deletable (4 B)
segments (28 B)
version.txt (21 B)
-8t.cfs (314 K)
file : search.html
file : search_result.xls
thanks
Shilpa Toraskar wrote:
> From log LD> _indexPath: null
> it looks like
> _indexPath: null means that no index is available. analyzerName is the
> name of analyzer used for generating index which is null.
> Thanks
> Shilpa
Re: epf search ? [message #44951 is a reply to message #44927] Fri, 26 October 2007 12:58 Go to previous messageGo to next message
Could you try Tomcat? I would like to nail down the issue to see .war
file is not working correctly on weblogic?
Shilpa
Re: epf search ? [message #45094 is a reply to message #44951] Mon, 29 October 2007 03:31 Go to previous message
Shilpa,
I've tested using Tomcat 6.0.14 and everything works just fine.
So it seems there is a Weblogic related problem
Thanks for the help.
Danny
> Shilpa
Re: epf search ? [message #585254 is a reply to message #44778] Tue, 23 October 2007 15:27 Go to previous message
From log
it looks like
null.
Shilpa
Re: epf search ? [message #585281 is a reply to message #44877] Fri, 26 October 2007 03:11 Go to previous message
Shilpa
dir : images
dir : index
deletable (4 B)
segments (28 B)
version.txt (21 B)
-8t.cfs (314 K)
file : search.html
thanks
> it looks like
> Thanks
> Shilpa
Re: epf search ? [message #585296 is a reply to message #44927] Fri, 26 October 2007 12:58 Go to previous message
Shilpa
Re: epf search ? [message #585307 is a reply to message #44951] Mon, 29 October 2007 03:31 Go to previous message
Shilpa,
Danny
> Shilpa
Previous Topic:Eclipse Way
Next Topic:OpenUp white paper in french
Current Time: Thu Jul 17 11:48:23 EDT 2025
Powered by FUDForum. Page generated in 0.31057 seconds
