epf search ? [message #44778] |
Mon, 22 October 2007 05:47  |
I published a simple method to a .war file
deployed it (to weblogic 8.1)
website OK
but search doesn't give any results and I get the following stacktrace :
LD> searchString: group
convert group -> group
LD> _indexPath: null
LD> _currentSearchString: group
LD> unicodes: group
LD> analyzerName: null
LD> _hits: null
org.eclipse.epf.web.servlet.SearchServlet.runQuery(Ljava.lan g.String;
)Z(SearchServlet.java:206)
org.eclipse.epf.web.servlet.SearchServlet.runSearch(Ljava.la ng.String
;)Ljava.lang.String;(SearchServlet.java:174)
org.eclipse.epf.web.servlet.SearchServlet.doGet(Ljavax.servl et.http.H
ttpServletRequest;Ljavax.servlet.http.HttpServletResponse;)V (SearchServlet.java:
129)
javax.servlet.http.HttpServlet.service(Ljavax.servlet.http.H ttpServle
tRequest;Ljavax.servlet.http.HttpServletResponse;)V(HttpServ let.java:740)
javax.servlet.http.HttpServlet.service(Ljavax.servlet.Servle tRequest;
Ljavax.servlet.ServletResponse;)V(HttpServlet.java:853)
weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run
()Ljava.lang.Object;(ServletStubImpl.java:1006)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Ljav ax.servle
t.ServletRequest;Ljavax.servlet.ServletResponse;Lweblogic.se rvlet.internal.Filte
rChainImpl;)V(ServletStubImpl.java:419)
t.ServletRequest;Ljavax.servlet.ServletResponse;)V(ServletSt ubImpl.java:315)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionActio
n.run()Ljava.lang.Object;(WebAppServletContext.java:6718)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Lwe blogic.se
curity.subject.AbstractSubject;Ljava.security.PrivilegedActi on;)Ljava.lang.Objec
t;(AuthenticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(Lweblogic.se curity.ac
l.internal.AuthenticatedSubject;Lweblogic.security.acl.inter nal.AuthenticatedSub
ject;Ljava.security.PrivilegedAction;)Ljava.lang.Object;(Sec urityManager.java:12
1)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (Lweblogi
c.servlet.internal.ServletRequestImpl;Lweblogic.servlet.inte rnal.ServletResponse
Impl;)V(WebAppServletContext.java:3764)
weblogic.servlet.internal.ServletRequestImpl.execute(Lweblog ic.kernel
..ExecuteThread;)V(ServletRequestImpl.java:2644)
weblogic.kernel.ExecuteThread.execute(Lweblogic.kernel.Execu teRequest
;)V(ExecuteThread.java:219)
at weblogic.kernel.ExecuteThread.run()V(ExecuteThread.java:178)
java.lang.Thread.startThreadFromVM(Ljava.lang.Thread;)V(Unkn own Sourc
e)
Re: epf search ? [message #45094 is a reply to message #44951] |
Mon, 29 October 2007 03:31  |
Shilpa,
I've tested using Tomcat 6.0.14 and everything works just fine.
So it seems there is a Weblogic related problem
Thanks for the help.
Danny
Shilpa Toraskar wrote:
> Could you try Tomcat? I would like to nail down the issue to see .war
> file is not working correctly on weblogic?
> Shilpa
Re: epf search ? [message #585254 is a reply to message #44778] |
Tue, 23 October 2007 15:27  |
From log
it looks like
_indexPath: null means that no index is available.
analyzerName is the name of analyzer used for generating index which is
null.
Can you try the following and see whether any of this makes a difference ?
1. check the deployed web app's search dir has the right files
2. try deploying it on Tomcat,
3. try OpenUP on Tomcat,
4. try OpenUP on WebLogic.
Shilpa
Re: epf search ? [message #585281 is a reply to message #44877] |
Fri, 26 October 2007 03:11  |
Shilpa
- Deployed OpenUP to Weblogic - same error
the search dir contains the following :
dir : images
contains a lot of gifs
dir : index
deletable (4 B)
segments (28 B)
version.txt (21 B)
-8t.cfs (314 K)
file : search.html
file : search_result.xls
thanks
> From log LD> _indexPath: null
> it looks like
> _indexPath: null means that no index is available. analyzerName is the
> name of analyzer used for generating index which is null.
> Thanks
> Shilpa
Re: epf search ? [message #585307 is a reply to message #44951] |
Shilpa,
Danny
> Shilpa
FUDForum. Page generated in 0.04701 seconds
