how to refer to the same instance of the model from different notation diagrams [message #44757] |
Mon, 11 September 2006 08:20  |
Originally posted by: marguu.libero.it
Hi all! I'd like to know how I can refer to the same instance of the mod=
el =
from different instances of the diagram. I've modified the code of my g=
mf =
editor to point always t the same model file, but i'd like to be able to=
operate on a unique instance in memory of the root element of the resour=
ce =
associated with this file. How can I reach this aim?
Thanks in advance
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
SOLVED Re: how to refer to the same instance of the model from different notation diagrams [message #46644 is a reply to message #46598] |
Tue, 12 September 2006 11:12  |
Thanks a lot! Now I'll post the CommandStack problem in a new thread in =
order to give it a gretaer visibility!
Thanks Angelo
On Tue, 12 Sep 2006 14:44:24 +0000 (UTC), Alex Shatalin <vano@borland.co=
m> =
wrote:
> Hello Angelo,
>> "document.setContent(document.getContent());" works. In fact if I
>> comment this line in the DemultiplexingListener.handleNotification()
>> operation, I obtain the wanted result!
> This is a listener for change notifications from the underlying =
> resources. Once you change any of the resources loaded into the resour=
ce =
> set associated with openned diagram, then =
> "document.setContent(document.getContent());" will be called to mark =
> editor is dirty. I do not think you should mark only one editor as =
> "dirty" because if you'll try to open another diagram referencing the =
> same model instance (this is what are you going to do AFAIU) and make =
> any modifications in the underlying model - another diagram will be =
> changed as well, so editor should be marked as dirty. But you can try =
it.
> Concerning CommandStack =E2=80=93 I suggest you to wait a bit and I=
hope =
> somebody from the runtime team will post an answer to this question. =
> Runtime is just a part of GMF, but I=E2=80=99m not responsible for it =
and simply =
> can not answer some concrete questions especially concerning command =
> processing. ;-)
> Alex Shatalin
FUDForum. Page generated in 0.28595 seconds
