Home » Modeling » BPEL Designer » Example is not working on new version
Example is not working on new version [message #3899] Wed, 29 March 2006 01:33 Go to next message
I finally managed to get the plugins compiled. when applying it to the
example
in the cvs it can not be staretd with the current version. Any ideas what
to
change?
I get the following error:
org.eclipse.emf.common.util.WrappedException:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http://schemas.xmlsoap.org/ws/2004/03/business-process/' not found.
(platform:/resource/org.eclipse.bpel.examples.simple/SampleP rocess.bpel, 2,
373)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
org.eclipse.bpel.common.ui.editmodel.ResourceInfo.load(Resou rceInfo.java:126)
org.eclipse.bpel.common.ui.editmodel.EditModel.getResourceIn fo(EditModel.java:153)
org.eclipse.bpel.common.ui.editmodel.EditModelClient.<init>(EditModelClient.java:61)
org.eclipse.bpel.ui.util.BPELEditModelClient.<init>(BPELEditModelClient.java:47)
at org.eclipse.bpel.ui.BPELEditor.init(BPELEditor.java:1545)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:825)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:578)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:367)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:555)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:212)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2392)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2325)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2317)
org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2303)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2298)
org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:284)
org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:276)
org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:183)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3287)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2907)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Example is not working on new version [message #3905 is a reply to message #3899] Wed, 29 March 2006 08:26 Go to previous messageGo to next message
try the following:
http://schemas.xmlsoap.org/ws/2003/03/business-process/
It seems to have "2004" in there by mistake...
Darren
Re: Example is not working on new version [message #3911 is a reply to message #3905] Wed, 29 March 2006 09:01 Go to previous messageGo to next message
I tried your recommendation, but it didn't worked. Any other idea maybe?
Re: Example is not working on new version [message #3917 is a reply to message #3905] Wed, 29 March 2006 09:03 Go to previous messageGo to next message
Thanks for the hint. I tried it but I still get the same error.
Maybe you have another hint?
thanks in advance.
Re: Example is not working on new version [message #3923 is a reply to message #3905] Wed, 29 March 2006 19:21 Go to previous messageGo to next message
Darren wrote:
> try the following:
> Cheers,
> Darren
Actually 2004 is correct, and the code should recognize it. The 2003 is
from an earlier version of the BPEL spec. See the latest posted OASIS
XSD here:
http://www.oasis-open.org/committees/download.php/16074/wsbp el_main-2005-12-22.xsd
james
Re: Example is not working on new version [message #3936 is a reply to message #3911] Fri, 31 March 2006 03:23 Go to previous message
I followed literally the installation instructions, that is, generating
the projects from the cvs directly, launching the application and it works
now.
Although I have no clue why it has not worked before.
Thanks for the comments and the good support.
cheers
Andreas
Previous Topic:JBoss interest in BPEL designer
Next Topic:What is the Workflow Extension planed for M6
Current Time: Sat Jul 26 09:16:35 EDT 2025
Powered by FUDForum. Page generated in 0.46489 seconds
