Home » Archived » DSDP - Real-Time Software Components (RTSC) » Re-throwing an error
Re-throwing an error [message #3895] |
Tue, 09 June 2009 12:04  |
Champs,
Is it safe to call Error_raise() on a signaled error block? Or might some state information from the previous error "leak" into the second error and invalidate its state?
For example, I have some code which requests memory. If the heap runs out of memory, it will raise an error. But this is a low level and very common operation. I would like to add a second error event to the error log which indicates who was requesting the memory.
packet = (RcmClient_Packet*)Memory_alloc(NULL, size, sizeof(Ptr), eb);
if (Error_check(eb)) {
Error_raise(eb, RcmClient_E_packetAllocFailed, size, 0);
goto leave;
Is this safe to do, or must I call Error_init() before raising the second error?
~ Ramsey
Re: Re-throwing an error [message #3902 is a reply to message #3895] |
Wed, 10 June 2009 11:47   |
Originally posted by: bob.biosbob.biz
from what i can tell, calling Error_init (again!) will effectively reset
the error block.... [i seem to recall an Error_clear function from the
past, though its implementation was probably just a called to Error_init
and was therefore dropped]
as an alternative, however, the function below (which is passed 'eb')
could declare its *own* Error_Block on the stack; the latter Error_Block
would be passed to Memory_alloc and -- depending upon the outcome -- the
original 'eb' would be passed to Error_raise....
this approach would be *necessary* if this particular routine want to do
some cleanup *before* calling Error_raise on the original 'eb'.... why?
because 'eb' could be NULL and passing it to Memory_alloc could lead to
premature program termination....
this design also enforces the "one error per one error block" approach...
but still, you can reuse error blocks by simply calling Error_init (again!)
Ramsey Harris wrote:
> Champs,
> goto leave;
> second error?
> Thanks
> ~ Ramsey
Re: Re-throwing an error [message #3908 is a reply to message #3902] |
Wed, 10 June 2009 14:01   |
Interesting idea, creating a local error block. Thanks for that.
But my original question was really just asking if its okay to call Error_raise() on a signaled error block *without* first calling Error_init(). I would rather not have to call Error_init() if I don't need to.
~ Ramsey
>> Champs,
>> goto leave;
>> second error?
>> Thanks
>> ~ Ramsey
Re: Re-throwing an error [message #3914 is a reply to message #3908] |
Thu, 11 June 2009 17:48  |
Error_raise calls Error_init internally. Also, the docs state:
"If Error_raise is called more than once on an Error_Block object, the
previous error information is overwritten; only the last error is retained
in the Error_Block object."
http://rtsc.eclipse.org/cdoc-tip/xdc/runtime/Error.html#rais e
I guess we could explicitly say that Error_raise always call Error_init,
but on the other hand, that's not the only way to ensure that the
Error_Block object is completely overwritten by subsequent Error_raise
calls. Even now, Error_raise writes into each field of the Error_Block
object, so the call to Error_init is redundant.
I would rather leave docs as they are and leave the implementation details
out of the docs, in case that the internal call to Error_raise gets
removed to save a couple of cycles.
Current Time: Sat Jun 07 19:26:25 EDT 2025
Powered by FUDForum. Page generated in 0.03080 seconds
