Home » Modeling » GMF (Graphical Modeling Framework) » Diagram preferences
Diagram preferences [message #44722] Mon, 11 September 2006 08:18 Go to next message
I added MyDiagramsPreferencePage to org.eclipse.ui.preferencePages
extension point, there exists my diagram preference page, but setting them
does not affect diagram behavior. For example, I set "Show popup bars" to
false, but there is still bars prompting. Anything additional step I
should do?
Zhang Hao
Re: Diagram preferences [message #45301 is a reply to message #44722] Mon, 11 September 2006 14:56 Go to previous messageGo to next message
Originally posted by: cmahoney.ca.ibm.com
Zhang Hao,
Did you take a look at this tutorial?
http://help.eclipse.org/help31/topic/org.eclipse.gmf.doc/tut orials/diagram/diagramPreferencesTutorial.html
You are probably missing the step, "Registering the Preference Store".
Cherie
Hao Zhang wrote:
> them does not affect diagram behavior. For example, I set "Show popup
> bars" to false, but there is still bars prompting. Anything additional
> step I should do?
> Zhang Hao
Re: Diagram preferences [message #45519 is a reply to message #45301] Tue, 12 September 2006 01:27 Go to previous messageGo to next message
It has been generated in MyDiagramEditorPlugin#startup(), but it seems the
PreferencesHint uses plugin id rather than editor id, I modified
PreferencesHint.registerPreferenceStore(DIAGRAM_PREFERENCES_ HINT,
getPreferenceStore());
into
PreferencesHint.registerPreferenceStore(new
PreferencesHint("com.my.diagram.part.MyDiagramEditorID"),
then it works.
A generation template bug?
Cherie Revells (Mahoney) wrote:
> Zhang Hao,
> Cherie
> Hao Zhang wrote:
>> step I should do?
>> Regards,
>> Zhang Hao
Re: Diagram preferences [message #46308 is a reply to message #45519] Tue, 12 September 2006 09:00 Go to previous message
Generated code references preferenceStore associated with
DIAGRAM_PREFERENCES_HINT, so it's doubtful
registerPreferenceStore(anotherId) works unless you modified rest of the
code to use same id. If it's the case, file the bug, please.
Artem
"Hao Zhang" <bjzhanghao@21cn.com> wrote in message
news:2c2759bbdf6e75f60ccd2e22790d24ac$1@www.eclipse.org...
> into
> then it works.
>> Zhang Hao,
>> Regards,
>> Cherie
>> Hao Zhang wrote:
>>> Hi,
>>> step I should do?
>>> Regards,
>>> Zhang Hao
Previous Topic:Multiple editpart objects with numbers in name
Next Topic:Re: EMFCoreUtil.getReferencers returns empty set
Current Time: Wed Jul 16 19:57:14 EDT 2025
Powered by FUDForum. Page generated in 0.26148 seconds
