Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT_AWT on PocketPC
SWT_AWT on PocketPC [message #444077] Wed, 06 October 2004 13:58 Go to next message
Originally posted by: dobrikov.rbg.informatik.tu-darmstadt.de
I want to use AWT with my SWT application, but the problem is that I am
running the application on PocketPC(J9 VM) platform and the SWT_AWT class
requires sun.awt.windows.WEmbeddedFrame which is not there and I can NOT
find it anywhere...How can I solve this problem...or is it possible to run
SWT_AWT class on PocketPc(SWT and AWT together...)?
Thanks in advance...
Todor
Re: SWT_AWT on PocketPC [message #444136 is a reply to message #444077] Thu, 07 October 2004 10:46 Go to previous messageGo to next message
Hi Todor,
SWT_AWT is not supported on the Pocket PC, for the reason you mention.You
can ask on the WSDD newsgroup if they know whether is possible to mix their
AWT - which I believe is using a subset of SWT - with SWT code or not.
news://news.software.ibm.com/ibm.software.websphere.studio.d evice-developer
Chris
Re: SWT_AWT on PocketPC [message #444161 is a reply to message #444136] Fri, 08 October 2004 03:38 Go to previous messageGo to next message
I've asked on the WSDD newsgroup, but now my question is: is there
posibility to use AWT and SWT together without SWT_AWT connection class..?
Todor
Christophe Cornu wrote:
> Hi Todor,
> Chris
Re: SWT_AWT on PocketPC [message #444207 is a reply to message #444161] Fri, 08 October 2004 10:52 Go to previous message
Hi Todor,
Mixing SWT and AWT is not supported on the Pocket PC.
Chris
Previous Topic:How to edit a desired TreeItem of a Tree
Next Topic:API for getting Tooltip delay?
Current Time: Sat Jul 12 22:17:50 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
