Home » Archived » XML Schema Definition (XSD) » Resource notifications
Resource notifications [message #44597] Mon, 17 May 2004 11:08 Go to next message
Ed,
I am pretty sure this is not an XSD specific issue, but it is
manifesting itself with XSDResources, so we'll start there. If I right
click an XSDResource in the workspace and bring up the resource properties.
Changing the read only status of the resource does not seem to produce any
notifications. I have breakpoints is the delta processor for the resources
as well as the notification processor... neither receive anything when I
change that state. Is that expected, or are we missing something?
thanks,
lp
Re: Resource notifications [message #44628 is a reply to message #44597] Mon, 17 May 2004 11:15 Go to previous messageGo to next message
Lance,
The resource delta support is part of the platform so you'll need to ask them
about it.
Lance Phillips wrote:
> Ed,
> thanks,
> lp
Re: Resource notifications [message #44659 is a reply to message #44628] Mon, 17 May 2004 11:56 Go to previous messageGo to next message
Thanks Ed!
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:40A8D71D.33FC8542@ca.ibm.com...
> Lance,
them
> about it.
> > Ed,
properties.
any
resources
> > thanks,
> > lp
Re: Resource notifications [message #45470 is a reply to message #44659] Tue, 25 May 2004 11:24 Go to previous messageGo to next message
Ed,
I finally got a chance to get back to this. Here is the problem... the
events ARE getting processed, but the resource is never marked as dirty and
no notifications come out of the change.
The method in question is elementAttributeChanged on
XSDConcreteComponentImpl. It seems that notifications need to fired here
and at a minimum the resource needs to be marked as dirty???
thanks,
lp
"Lance Phillips" <lphillips@metamatrix.com> wrote in message
news:c8amte$f8h$1@eclipse.org...
> Thanks Ed!
> lp
> > Lance,
> them
> > about it.
> > > Ed,
right
> properties.
> any
> resources
I
> > > thanks,
> > > lp
Re: Resource notifications [message #45588 is a reply to message #45470] Tue, 25 May 2004 12:16 Go to previous messageGo to next message
Lance,
The sample editor doesn't do resource delta listening. Is that what you are
getting at?
> Ed,
> thanks,
> lp
> > Thanks Ed!
> > lp
> > > Lance,
> > them
> > > about it.
> > > > Ed,
> right
> > properties.
> > any
> > resources
> I
> > > > thanks,
> > > > lp
Re: Resource notifications [message #45618 is a reply to message #45588] Tue, 25 May 2004 13:01 Go to previous messageGo to next message
Wrong thread.... sorry.
My issue was actually with changing the value of one of the DOM attributes
we've added to our objects. When we change one of those values in the
property editor we don't get a notification or resource dirty change. As
refresher for you, we hang some user properties as DOM Attr entities under
the XSDAnotation for our XSDSimpleTypeDefinitions. We see the properties
fine in our editor and are able to change them fine. It gets into the
method mentioned above fine, but we end up with no notifications and the
resource still shows as not dirty.
Sorry for the confusion.
thanks,
lp
news:40B3715B.F66AC009@ca.ibm.com...
> Lance,
are
> getting at?
> > Ed,
the
and
here
> > thanks,
> > lp
> > > Thanks Ed!
> > > lp
> > > > Lance,
ask
> > > them
> > > > about it.
> > > > > Ed,
> > right
> > > properties.
produce
> > > any
> > > resources
when
> > I
> > > > > thanks,
> > > > > lp
Re: Resource notifications [message #45678 is a reply to message #45618] Tue, 25 May 2004 13:09 Go to previous messageGo to next message
Lance,
Did you modify the DOM without using a command?
> thanks,
> lp
> > Lance,
> are
> > getting at?
> > > Ed,
> the
> and
> here
> > > thanks,
> > > lp
> > > > Thanks Ed!
> > > > lp
> > > > > Lance,
> ask
> > > > them
> > > > > about it.
> > > > > > Ed,
> > > right
> > > > properties.
> produce
> > > > any
> > > > resources
> when
> > > I
> > > > > > thanks,
> > > > > > lp
Re: Resource notifications [message #45997 is a reply to message #45678] Wed, 26 May 2004 10:40 Go to previous messageGo to next message
Yes! Could you point me at a code example of how to use a set command for a
DOM entity?
thanks,
lp
news:40B37DDF.3FF74443@ca.ibm.com...
> Lance,
attributes
As
under
properties
> > thanks,
> > lp
> > > Lance,
you
> > are
> > > getting at?
> > > > Ed,
problem...
> > the
dirty
> > and
> > here
> > > > thanks,
> > > > lp
> > > > > Thanks Ed!
> > > > > lp
> > > > > > Lance,
need to
> > ask
> > > > > them
> > > > > > about it.
> > > > > > > Ed,
is
If I
> > > > right
resource
> > > > > properties.
> > produce
> > > > > any
the
> > > > > resources
anything
> > when
> > > > I
something?
> > > > > > > thanks,
> > > > > > > lp
Re: Resource notifications [message #46030 is a reply to message #45997] Wed, 26 May 2004 11:09 Go to previous messageGo to next message
Lance,
You need to write your own command to do this. You can follow the way the
emf.edit commands are written.
> DOM entity?
> thanks,
> lp
> > Lance,
> attributes
> As
> under
> properties
> > > thanks,
> > > lp
> > > > Lance,
> you
> > > are
> > > > getting at?
> > > > > Ed,
> problem...
> > > the
> dirty
> > > and
> > > here
> > > > > thanks,
> > > > > lp
> > > > > > Thanks Ed!
> > > > > > lp
> > > > > > > Lance,
> need to
> > > ask
> > > > > > them
> > > > > > > about it.
> > > > > > > > Ed,
> is
> If I
> > > > > right
> resource
> > > > > > properties.
> > > produce
> > > > > > any
> the
> > > > > > resources
> anything
> > > when
> > > > > I
> something?
> > > > > > > > thanks,
> > > > > > > > lp
Re: Resource notifications [message #46060 is a reply to message #46030] Wed, 26 May 2004 14:04 Go to previous messageGo to next message
OK... I've written my own command to perform this change within a command.
I modeled my command after the SetCommand.
What do I have to do in my doExecute method to cause some notifications to
get fired? I have the XSDSimpleType definition that owns the Annotation.
But, it does not think that it has changed at the end of this process.
thanks,
lp
news:40B4B330.F7C465DB@ca.ibm.com...
> Lance,
for a
> > DOM entity?
> > thanks,
> > lp
> > > Lance,
> > attributes
the
change.
> > As
> > under
> > properties
the
the
> > > > thanks,
> > > > lp
> > > > > Lance,
what
> > you
> > > > are
> > > > > getting at?
> > > > > > Ed,
> > problem...
> > > > the
as
> > dirty
> > > > and
fired
> > > > here
> > > > > > thanks,
> > > > > > lp
> > > > > > > Thanks Ed!
> > > > > > > lp
> > > > > > > > Lance,
> > need to
> > > > ask
> > > > > > > them
> > > > > > > > about it.
> > > > > > > > > Ed,
but it
> > is
there.
> > If I
> > > > > > right
> > resource
> > > > > > > properties.
seem to
> > > > produce
> > > > > > > any
for
> > the
> > > > > > > resources
> > anything
> > > > when
> > > > > > I
> > something?
> > > > > > > > > thanks,
> > > > > > > > > lp
Re: Resource notifications [message #46088 is a reply to message #46060] Wed, 26 May 2004 14:21 Go to previous message
Nevermind... I've got it.
Thanks for the help Ed!
lp
news:c92lpf$p8$1@eclipse.org...
> thanks,
> lp
> > Lance,
the
> for a
> > > DOM entity?
> > > thanks,
> > > lp
> > > > Lance,
> > > attributes
> the
> change.
> > > As
entities
> > > under
> > > properties
> the
and
> the
> > > > > thanks,
> > > > > lp
> > > > > > Lance,
> what
> > > you
> > > > > are
> > > > > > getting at?
> > > > > > > Ed,
> > > problem...
> > > > > the
> as
> > > dirty
> > > > > and
> fired
> > > > > here
> > > > > > > thanks,
> > > > > > > lp
> > > > > > > > Thanks Ed!
> > > > > > > > lp
> > > > > > > > > Lance,
you'll
> > > need to
> > > > > ask
> > > > > > > > them
> > > > > > > > > about it.
> > > > > > > > > > Ed,
> but it
> > > is
> there.
> > > If I
> > > > > > > right
> > > resource
> > > > > > > > properties.
> seem to
> > > > > produce
> > > > > > > > any
processor
> for
> > > the
> > > > > > > > resources
> > > anything
> > > > > when
> > > > > > > I
> > > something?
> > > > > > > > > > thanks,
> > > > > > > > > > lp
Re: Resource notifications [message #587138 is a reply to message #44597] Mon, 17 May 2004 11:15 Go to previous message
Lance,
about it.
> Ed,
> thanks,
> lp
Re: Resource notifications [message #587149 is a reply to message #44628] Mon, 17 May 2004 11:56 Go to previous message
Thanks Ed!
lp
> Lance,
them
> about it.
> > Ed,
properties.
any
resources
> > thanks,
> > lp
Re: Resource notifications [message #587497 is a reply to message #44659] Tue, 25 May 2004 11:24 Go to previous message
Ed,
thanks,
lp
> Thanks Ed!
> lp
> > Lance,
> them
> > about it.
> > > Ed,
right
> properties.
> any
> resources
I
> > > thanks,
> > > lp
Re: Resource notifications [message #587562 is a reply to message #45470] Tue, 25 May 2004 12:16 Go to previous message
Lance,
getting at?
> Ed,
> thanks,
> lp
> > Thanks Ed!
> > lp
> > > Lance,
> > them
> > > about it.
> > > > Ed,
> right
> > properties.
> > any
> > resources
> I
> > > > thanks,
> > > > lp
Re: Resource notifications [message #587570 is a reply to message #45588] Tue, 25 May 2004 13:01 Go to previous message
thanks,
lp
> Lance,
are
> getting at?
> > Ed,
the
and
here
> > thanks,
> > lp
> > > Thanks Ed!
> > > lp
> > > > Lance,
ask
> > > them
> > > > about it.
> > > > > Ed,
> > right
> > > properties.
produce
> > > any
> > > resources
when
> > I
> > > > > thanks,
> > > > > lp
Re: Resource notifications [message #587591 is a reply to message #45618] Tue, 25 May 2004 13:09 Go to previous message
Lance,
> thanks,
> lp
> > Lance,
> are
> > getting at?
> > > Ed,
> the
> and
> here
> > > thanks,
> > > lp
> > > > Thanks Ed!
> > > > lp
> > > > > Lance,
> ask
> > > > them
> > > > > about it.
> > > > > > Ed,
> > > right
> > > > properties.
> produce
> > > > any
> > > > resources
> when
> > > I
> > > > > > thanks,
> > > > > > lp
Re: Resource notifications [message #587685 is a reply to message #45678] Wed, 26 May 2004 10:40 Go to previous message
DOM entity?
thanks,
lp
> Lance,
attributes
As
under
properties
> > thanks,
> > lp
> > > Lance,
you
> > are
> > > getting at?
> > > > Ed,
problem...
> > the
dirty
> > and
> > here
> > > > thanks,
> > > > lp
> > > > > Thanks Ed!
> > > > > lp
> > > > > > Lance,
need to
> > ask
> > > > > them
> > > > > > about it.
> > > > > > > Ed,
is
If I
> > > > right
resource
> > > > > properties.
> > produce
> > > > > any
the
> > > > > resources
anything
> > when
> > > > I
something?
> > > > > > > thanks,
> > > > > > > lp
Re: Resource notifications [message #587696 is a reply to message #45997] Wed, 26 May 2004 11:09 Go to previous message
Lance,
> DOM entity?
> thanks,
> lp
> > Lance,
> attributes
> As
> under
> properties
> > > thanks,
> > > lp
> > > > Lance,
> you
> > > are
> > > > getting at?
> > > > > Ed,
> problem...
> > > the
> dirty
> > > and
> > > here
> > > > > thanks,
> > > > > lp
> > > > > > Thanks Ed!
> > > > > > lp
> > > > > > > Lance,
> need to
> > > ask
> > > > > > them
> > > > > > > about it.
> > > > > > > > Ed,
> is
> If I
> > > > > right
> resource
> > > > > > properties.
> > > produce
> > > > > > any
> the
> > > > > > resources
> anything
> > > when
> > > > > I
> something?
> > > > > > > > thanks,
> > > > > > > > lp
Re: Resource notifications [message #587704 is a reply to message #46030] Wed, 26 May 2004 14:04 Go to previous message
thanks,
lp
> Lance,
for a
> > DOM entity?
> > thanks,
> > lp
> > > Lance,
> > attributes
the
change.
> > As
> > under
> > properties
the
the
> > > > thanks,
> > > > lp
> > > > > Lance,
what
> > you
> > > > are
> > > > > getting at?
> > > > > > Ed,
> > problem...
> > > > the
as
> > dirty
> > > > and
fired
> > > > here
> > > > > > thanks,
> > > > > > lp
> > > > > > > Thanks Ed!
> > > > > > > lp
> > > > > > > > Lance,
> > need to
> > > > ask
> > > > > > > them
> > > > > > > > about it.
> > > > > > > > > Ed,
but it
> > is
there.
> > If I
> > > > > > right
> > resource
> > > > > > > properties.
seem to
> > > > produce
> > > > > > > any
for
> > the
> > > > > > > resources
> > anything
> > > > when
> > > > > > I
> > something?
> > > > > > > > > thanks,
> > > > > > > > > lp
Re: Resource notifications [message #587713 is a reply to message #46060] Wed, 26 May 2004 14:21 Go to previous message
lp
> thanks,
> lp
> > Lance,
the
> for a
> > > DOM entity?
> > > thanks,
> > > lp
> > > > Lance,
> > > attributes
> the
> change.
> > > As
entities
> > > under
> > > properties
> the
and
> the
> > > > > thanks,
> > > > > lp
> > > > > > Lance,
> what
> > > you
> > > > > are
> > > > > > getting at?
> > > > > > > Ed,
> > > problem...
> > > > > the
> as
> > > dirty
> > > > > and
> fired
> > > > > here
> > > > > > > thanks,
> > > > > > > lp
> > > > > > > > Thanks Ed!
> > > > > > > > lp
> > > > > > > > > Lance,
you'll
> > > need to
> > > > > ask
> > > > > > > > them
> > > > > > > > > about it.
> > > > > > > > > > Ed,
> but it
> > > is
> there.
> > > If I
> > > > > > > right
> > > resource
> > > > > > > > properties.
> seem to
> > > > > produce
> > > > > > > > any
processor
> for
> > > the
> > > > > > > > resources
> > > anything
> > > > > when
> > > > > > > I
> > > something?
> > > > > > > > > > thanks,
> > > > > > > > > > lp
Previous Topic:Base for relative schemaLocations
Next Topic:BaseType of a underived ComplexType
Current Time: Mon Sep 01 02:41:22 EDT 2025
Powered by FUDForum. Page generated in 1.06481 seconds
