Home » Eclipse Projects » Plugin Development Environment (PDE) » Imports can't resolved after eclipse restart
Imports can't resolved after eclipse restart [message #44577] Wed, 04 February 2009 04:20 Go to next message
I have a plugin, which contains some jars and some integration code. The
plugin works fine so far. But every time I restart eclipse PDE states of
unresolvable imports (org.junit in this case). The dependency is in the
manifest. I can take it out and put it back, no change.
The strange thing is, after reloading the target platform everything is
fine again. the projects builds again, the unresolved imports are gone
without changing a bit on the project.
Can someone give me a hint why that happen? I use Eclipse 3.4.1.
Thanks & Regards
Re: Imports can't resolved after eclipse restart [message #44682 is a reply to message #44577] Wed, 04 February 2009 05:02 Go to previous messageGo to next message
Maybe this helps: https://bugs.eclipse.org/bugs/show_bug.cgi?id=242002
Re: Imports can't resolved after eclipse restart [message #44771 is a reply to message #44682] Wed, 04 February 2009 07:10 Go to previous message
Thx, at least that states that it is fixed in 3.5. Good to know.
Re: Imports can't resolved after eclipse restart [message #591296 is a reply to message #44577] Wed, 04 February 2009 05:02 Go to previous message
Re: Imports can't resolved after eclipse restart [message #591317 is a reply to message #44682] Wed, 04 February 2009 07:10 Go to previous message
Previous Topic:Target Definition and deployed plugins = class path problem in build.xml
Next Topic:pde build with maven
Current Time: Sat Jul 26 16:03:39 EDT 2025
Powered by FUDForum. Page generated in 0.03136 seconds
