Home » Modeling » M2T (model-to-text transformation) » Accessing set variable in Java as String
Accessing set variable in Java as String [message #44575] Thu, 24 April 2008 14:12 Go to next message
My input looks like this:
<data>
<wrap>
<in package="com.foo" name="Foo"/>
<out project="my.proj" package="com.bar" name="Foo"/>
</wrap>
</data>
Here is my template fragment:
<c:iterate select="/data/wrap" var="wrap">
<c:setVariable var="interfaceName" select="$wrap/in/@name"/>
String interfaceName = (String)context.getVariable("interfaceName");
</c:iterate>
When I try to run this code I get a casting exception. It is returning a
NodeSetImpl rather than a String.
Re: Accessing set variable in Java as String [message #44613 is a reply to message #44575] Thu, 24 April 2008 21:50 Go to previous message
Try:
<c:setVariable var="interfaceName" select="string($wrap/in/@name)"/>
XPath expressions like $wrap/in/@name don't actually return strings, they
return 'nodes' in the input model. Most of the time, JET converts these to
strings for you.
Paul
"Jeffrey Ricker" <ricker@jeffreyricker.com> wrote in message
news:fuqii3$u8r$1@build.eclipse.org...
> <data>
> <wrap>
> </wrap>
> </data>
> </c:iterate>
Previous Topic:Problem with update site
Next Topic:does an eclipse project clean delete the jet2java sources ?
Current Time: Sun Aug 31 00:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.02528 seconds
