Home » Eclipse Projects » Nebula » CDateTime textbox not applying selection from popup if not selected with enter or mouseclick
CDateTime textbox not applying selection from popup if not selected with enter or mouseclick [message #44572] Wed, 05 December 2007 17:44
I have a question about CDateTime. When the popup is used and a date is not
selected with "enter" or a mouse click (instead I select a time with the
arrow keys and then click outside the popup), the arrow keys update the
text, but when the popup closes, the textbox resets to the date before the
popup. I imagine this may be intended behavior but I wanted to be sure? I
believe intuitive behavior would cause the date to be selected whether you
click the specific time or whether you click outside (take the combo box as
an example).
Another question also having to do with the popup: When Page Up/Down, Home
and End are used to navigate the calendar, the textbox does not update with
each key stroke. When Enter is pushed, the textbox does update. Navigating
the calendar with the arrow keys does however update the textbox.
Thanks!
David
Previous Topic:Re: Using Nebula CalendarCombo and DataBinding
Next Topic:CDateTime textbox not applying selection from popup if not selected with enter or mouseclick
Current Time: Tue Jul 22 19:12:44 EDT 2025
Powered by FUDForum. Page generated in 0.02656 seconds
