Home » Language IDEs » PHP Development Tools (PDT) » europa?
europa? [message #44529] Mon, 20 August 2007 00:55 Go to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Hi all,
I recently upgraded to Eclipse Europa release and PDT I20070816.
Would I be right in thinking that this particular combination is not
really considered 'stable' as yet? (Obviously integration builds are not
supposed to be stable but as I understood it, the I20070816 build was
the same as the S20070815 one).
I am getting a lot of wierd issues... too many to list here really, and
I won't bother filing bug reports if basically I am running PDT in an as
yet unsupported configuration.
Cheers
Tom
Re: europa? [message #44560 is a reply to message #44529] Mon, 20 August 2007 03:54 Go to previous messageGo to next message
Not really, generally speaking integration builds are not stable.
the last integration build is in particular not stable, but the one before
it was stable and was promoted to be the the milestone 2.
if you need stability - use M2
if you want to help us - use the last integration build and report for any
problem in buzilla (don't hasitate to open bugs - if it was fixed already
we will close it)
Bests,
Re: europa? [message #44755 is a reply to message #44560] Mon, 20 August 2007 19:58 Go to previous message
OK, bug reports coming up
> before it was stable and was promoted to be the the milestone 2.
> any problem in buzilla (don't hasitate to open bugs - if it was fixed
> already we will close it)
> Bests,
Previous Topic:Pre built Binary of XDebug Support
Next Topic:AJAX Toolkit Framework
Current Time: Fri Jul 25 02:35:47 EDT 2025
Powered by FUDForum. Page generated in 0.02449 seconds
