installation problem [message #44524] |
Thu, 10 October 2002 07:28  |
Hello all,
I am using eclipse 2.0.1 on red hat 8.0. I have downloaded the CDT from
http://www.eclipse.org/tools/index.html unzipped the contents into the
plugins folder. When eclipse comes up, and I go into update manager,
cdt is not listed there. When I see the display the disabled features I
see an error message "this feature is not configured properly. Plugin
"org.eclipse.cdt.core.qnx" version "1.0.0" referenced by this feature is
missing. PlugIN "org.eclipse.cdt.core.win32" version "1.0.0" referenced
by this feature is missing. Plugin "org.eclipse.cdt.core.win32" version
"1.0.0" referenced by this feature is missing.
does this mean that I cannot use eclipse for c/c++ dev on linux? because
it seems to be looking for solaris and win32 libraries !
regards,
Abhishek.
Re: installation problem [message #44974 is a reply to message #44586] |
Fri, 11 October 2002 09:11   |
Originally posted by: kuzman.zoominternet.net
I believe you still have a problem with the linux/GTK build.
I unzip the file into my eclipse directory and started eclipse.
When I started eclipse it displayed the Pending Configuration
Changes dialog with the plugin. I am unable to select the
plugin and when I push the Error Details button I get the
following error message:
Request operation cannot be performed because it would
invalidate the current configuration. See details for
more information.
When I press the details button I get:
Eclipse C/C++ Development Tools (1.0.0): Feature windowing
system does not match the current environment.
I am running the GTK version of eclipse, RH 8.0, and am certain
that I am trying to install the GTK version of the C/C++ tools.
On Thu, 10 Oct 2002 11:45:04 +0000, Judy N. Green wrote:
> I checked the build.xml files and found that I had missed references to
> several of the platform specific plugins. They have been removed and new
> builds have been posted to the downloads page.
> Please try download and installation again.
> Sorry for the inconvienience.
> -Judy
> ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨ ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨
> Judy N. Green Software Engineer
> QNX Software Systems Ltd. www.qnx.com
> "Judy N. Green" <jgreen@qnx.com> wrote in message
> news:ao41pt$1tc$1@rogue.oti.com...
> | HI,
> | We just changed over to a new build process and could very well have
> missed
> | something.
> | Which version of the CDT are you using. Look for the build number in the
> | filename or on the about page?
> | The build number starts with 2002.
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/downloads/m
> | ain.html?cvsroot=Tools_Project
> | You should have F1 Linux (either Motif or GTK) from 2002/10/09
> | Let me know exactly which build you are using.
> | Thanks
> | -Judy
> | "Abhishek Srivastava" <abhishes@hotmail.com> wrote in message
> | news:ao3mrc$26q$1@rogue.oti.com...
> | | Hello all,
> | | regards,
> | | Abhishek.
Re: installation problem [message #45088 is a reply to message #44974] |
Fri, 11 October 2002 09:16   |
I have found the problem. You will need to update the
feature.xml file. You need to add gtk to the "ws" list
at the top of the file. Once this is added you can
install the plugin for linux/GTK.
-Jeff
> more information.
>> -Judy
>> | HI,
>> missed
>> | something.
>> | Thanks
>> | -Judy
>> | | Hello all,
>> | | regards,
>> | | Abhishek.
FUDForum. Page generated in 0.04238 seconds
