Home » Language IDEs » AspectJ » Isn't it too slow after using AJDT plugin?
Isn't it too slow after using AJDT plugin? [message #44501] Tue, 23 November 2004 21:46 Go to next message
Originally posted by: only4hj.softforum.com
I'm using AJDT 1.1.12 and Eclipse 3.0
Before I started using AJDT, it was OK.
But, after using that, my Eclipse got too slow.
It took too much time to compile projects I made before and had no AspectJ
files.
It seems that every work in Eclipse happens to take too much time after AJDT
installation.
I can't do anything with this slow Eclipse.
Are there any settings I can try?
Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #44536 is a reply to message #44501] Thu, 25 November 2004 09:06 Go to previous messageGo to next message
Dae-Joong wrote:
I assume you mean that your AspectJ projects and any projects that depend
upon them now take a long time to rebuild. The reason for this is that by
default AJDT does a complete build of your project when you save a file.
To change this check the "Use incremental compilation" option on the
"AspectJ" page of the project properties (see 1.1.12 documentation on
http://eclipse.org/ajdt/). A full build will still occur when changing
aspects.
> files.
> installation.
> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #44567 is a reply to message #44536] Thu, 25 November 2004 12:54 Go to previous messageGo to next message
If you mean that java file edition is slower for non-AspectJ projects,
it might be that the platform is set up to open java files with the
AjpectJ editor.
Check that in the preferences/workbench/file associations page.
Matthew Webster wrote:
> depend upon them now take a long time to rebuild. The reason for this is
> that by default AJDT does a complete build of your project when you save
> a file. To change this check the "Use incremental compilation" option on
> the "AspectJ" page of the project properties (see 1.1.12 documentation
> on http://eclipse.org/ajdt/). A full build will still occur when
> changing aspects.
>> AspectJ files.
>> after AJDT installation.
>> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #44596 is a reply to message #44567] Thu, 25 November 2004 21:19 Go to previous messageGo to next message
Thanks guys.
I've checked "Use incremental compilation" option and am using Default Java
Editor for *.java files.
Things are getting better. But I still have two problems.
One.
It takes long time when I close and open projects.
When I open or close a project, even though the project is not a AspectJ
project nor has no reference to
any AspectJ projects, it takes one minute or so.
When closing a project, a progress box shows up and says 'Operation in
process..', progress bar reaches to the end
and takes a whole CPU.
Two.
When I save a file with incremental build and automatic build turned on, it
consumes 100% CPU for 7 seconds
and Progress shows that 'Invoking Aspect Builder on /MyProject.'.
Even though the file I modified is not in build.ajproperties, it seems that
Aspect Builder does something.
There was no defference whether checking "Use incremental compilation" or
not.
My machine is Pentium IV 2.4 GHz, Windows XP.
Thanks.
"Guillaume Pothier" <gpothier@free.fr> wrote in message
news:co5696$6rn$1@www.eclipse.org...
> If you mean that java file edition is slower for non-AspectJ projects, it
> might be that the platform is set up to open java files with the AjpectJ
> editor.
>> aspects.
>>> AspectJ files.
>>> AJDT installation.
>>> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #44627 is a reply to message #44596] Fri, 26 November 2004 06:42 Go to previous messageGo to next message
Sounds like a bug. I remember there has been an issue some time ago with
builds that would trigger without logical cause...
Dae-Joong wrote:
> Thanks guys.
> One.
> Two.
> not.
> Thanks.
>>editor.
>>>aspects.
>>>>AspectJ files.
>>>>AJDT installation.
>>>>Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #44686 is a reply to message #44627] Mon, 29 November 2004 03:40 Go to previous messageGo to next message
> Dae-Joong wrote:
>> Thanks guys.
>> Two.
>> not.
Hi. Yes, this is a bug. I'm hoping to have the fix in sometime today.
Thanks, Helen
Re: Isn't it too slow after using AJDT plugin? [message #44913 is a reply to message #44596] Thu, 16 December 2004 09:03 Go to previous message
> any AspectJ projects, it takes one minute or so. When closing a project, a
> progress box shows up and says 'Operation in process..', progress bar
> reaches to the end and takes a whole CPU.
This should be improved in AJDT 1.2.0M2. I managed to reduce the scope of
our resource change listener to avoid processing deltas for non-AspectJ
projects. I'm also going to ask the Eclipse team if there is a better
solution here, or whether one can be added in the future, because there
still seems to be an overhead in calling our listener, even if we do
nothing with the delta.
Matt.
Re: Isn't it too slow after using AJDT plugin? [message #585077 is a reply to message #44501] Thu, 25 November 2004 09:06 Go to previous message
aspects.
> files.
> installation.
> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #585089 is a reply to message #44536] Thu, 25 November 2004 12:54 Go to previous message
AjpectJ editor.
> changing aspects.
>> AspectJ files.
>> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #585104 is a reply to message #44567] Thu, 25 November 2004 21:19 Go to previous message
Thanks guys.
One.
Two.
not.
Thanks.
> editor.
>> aspects.
>>> AspectJ files.
>>> AJDT installation.
>>> Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #585113 is a reply to message #44596] Fri, 26 November 2004 06:42 Go to previous message
Dae-Joong wrote:
> Thanks guys.
> One.
> Two.
> not.
> Thanks.
>>editor.
>>>aspects.
>>>>AspectJ files.
>>>>AJDT installation.
>>>>Thanks.
Re: Isn't it too slow after using AJDT plugin? [message #585140 is a reply to message #44627] Mon, 29 November 2004 03:40 Go to previous message
> Dae-Joong wrote:
>> Thanks guys.
>> Two.
>> not.
Thanks, Helen
Re: Isn't it too slow after using AJDT plugin? [message #585252 is a reply to message #44596] Thu, 16 December 2004 09:03 Go to previous message
Matt.
Previous Topic:AJDT 1.2.0M2 released
Next Topic:Something's strange about opening/closing projects
Current Time: Sat Jul 26 16:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.06001 seconds
