Home » Archived » OHF » Getting document consumer working with ohf 0.3.0?
Getting document consumer working with ohf 0.3.0? [message #44495] Wed, 23 July 2008 17:46 Go to next message
Originally posted by: frank.frederick.mckesson.com
I took a code snippet from
org.eclipse.ohf.ihe.xds.consumer.test.IBMLswin10RetrieveTest .testRetrieve().
I used the following info:
patientid - 139158
affinity domain - 1.3.6.1.4.1.21367.2005.3.7
assigning authority name - HIMSS2005
registry url -
http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/XDSb/SOAP11/R egistry
I got this info from the following url:
http://lswin10.dfw.ibm.com:9081/IBMIHII/serverInfoIHE_Connec tathonHIMSS2007.htm
When I run the test, I get no documents returned ... and no errors. I
suspect that some of the information I'm using is not correct, because
if I use the "Blue Panther Administration Portal" at
http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/index.jsp, I can query on
the patient id above and get 193 document references returned.
Can someone verify the consumer information I listed above?
Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44526 is a reply to message #44495] Wed, 23 July 2008 19:08 Go to previous messageGo to next message
hi Frank,
As you noted, you can browse the IBM Registry by patient id -
http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/query_docs.js p
.... so this may help with the confirmation part. Looks to be quite a few
documents. Note ... that there is no assigning authority name in the
registered id:
139158^^^&1.3.6.1.4.1.21367.2005.3.7&ISO
HIMSS2005 (or the assigning authority name) is a prohibited component of
patient id (as of 2006 XDS, not before). The registry does a pure string
match (not recognizing components). My guess is that this is the issue.
hope this helps,
- Sarah
> patientid - 139158
> registry url -
> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44618 is a reply to message #44526] Thu, 24 July 2008 11:23 Go to previous messageGo to next message
That definitely helped, one step closer. Now, in the log I see debug
messages like "Found 193 object references". I also see a dump of the
RegistryObjectList xml. I do not see any errors in the logs.
In that code snippet
when the following code is reached:
response.getDocumentEntryResponses().size()
zero is returned (where response is type XDSQueryResponseType). If I
call response.getReferences(), the EList contains 193 entries. I'm
unable to retrieve any documents.
Sarah Knoop wrote:
> hi Frank,
> registered id:
> hope this helps,
> - Sarah
>> patientid - 139158
>> registry url -
>> on the patient id above and get 193 document references returned.
>> Thanks,
>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44648 is a reply to message #44618] Thu, 24 July 2008 12:17 Go to previous messageGo to next message
Hi Frank,
I believe this is because you have the 'returnReferencesOnly' flag set
to true when you execute the query. Thus you only get back the list of
references to document metadata instead of the whole DocumentEntry
object that will contain the URL or document uniqueID that you need to
do the retrieve.
hope this helps,
Sarah
> Sarah Knoop wrote:
>> hi Frank,
>> few documents. Note ... that there is no assigning authority name in
>> the registered id:
>> of patient id (as of 2006 XDS, not before). The registry does a pure
>> string match (not recognizing components). My guess is that this is
>> the issue.
>> hope this helps,
>> - Sarah
>>> patientid - 139158
>>> registry url -
>>> I suspect that some of the information I'm using is not correct,
>>> because if I use the "Blue Panther Administration Portal" at
>>> Thanks,
>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44758 is a reply to message #44648] Thu, 24 July 2008 16:23 Go to previous messageGo to next message
Thanks, the javadoc was not clear on that boolean and I was thinking
that "reference" in this case was something else. I'm able to get a
list of document URLs now, but I'm not able to retrieve a document using
the code mentioned in earlier posts. The errors I run into area as follows
1) unknown host
example url:
http://ovs-backup1.cn.oracle.com:7777/XDSa/repository/iti17? e=Mi4xNi44NDAuMS4xMTM4OTQuMTAwNC4xMDAuMTAwLjIuNTAuNzc1&r =MS4xLjE=
2) No explict security domain
example url:
https://lswin10.dfw.ibm.com:9444/IBMXDSRepository/XDSa/Retri eveDocument?id=9440fc71-4b24-4a19-bca2-d6cbb6a541b6
I went back to the Blue Panther Administration Portal
I tried to retrieve a document for the patients in the table at:
I was not successful, I got similar errors trying to click on the links
displayed when a document query was executed in the portal.
Sarah Knoop wrote:
> Hi Frank,
> do the retrieve.
> hope this helps,
> Sarah
>> Sarah Knoop wrote:
>>> hi Frank,
>>> the registered id:
>>> the issue.
>>> hope this helps,
>>> - Sarah
>>>> patientid - 139158
>>>> registry url -
>>>> query on the patient id above and get 193 document references returned.
>>>> Thanks,
>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44810 is a reply to message #44758] Thu, 24 July 2008 17:19 Go to previous messageGo to next message
Hi Frank,
We have data from our North American Connectathon on the server. So some
documents are from this environment, which is no longer up (Example #1
below) Also, there are urls that were submitted using TLS and thus
require to be retrieved using TLS using the certificated issued at North
American connectathon. If you are interested in testing security at this
time, we can resurect the key and truststores. Otherwise - aim to
retrieve documents with urls beginning:
http://lswin10.dfw.ibm.com:9081/IBMXDSRepository/XDSa/Retrie veDocument?id=
Those documents have a chance of being on the system. Also of note --
the IBM servers are going to be moved soon, so some data may have been
cleansed to prepare for this.
A final way to ensure you have a document in the system is to use the
junit to submit the sample document(s) provided in the ohf document source.
Hope this helps,
- Sarah
> 1) unknown host
> example url:
> example url:
> Sarah Knoop wrote:
>> Hi Frank,
>> do the retrieve.
>> hope this helps,
>> Sarah
>>> the RegistryObjectList xml. I do not see any errors in the logs.
>>> Sarah Knoop wrote:
>>>> hi Frank,
>>>> the registered id:
>>>> component of patient id (as of 2006 XDS, not before). The registry
>>>> does a pure string match (not recognizing components). My guess is
>>>> hope this helps,
>>>> - Sarah
>>>>> patientid - 139158
>>>>> registry url -
>>>>> errors. I suspect that some of the information I'm using is not
>>>>> correct, because if I use the "Blue Panther Administration Portal"
>>>>> at http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/index.jsp, I can
>>>>> returned.
>>>>> Thanks,
>>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44841 is a reply to message #44810] Thu, 24 July 2008 17:42 Go to previous messageGo to next message
Thanks Sarah. I'll go to work on a getting a document submit code
snippet working with the OHF 0.3.0.
Sarah Knoop wrote:
> Hi Frank,
> Hope this helps,
> - Sarah
>> using the code mentioned in earlier posts. The errors I run into area
>> as follows
>> 1) unknown host
>> example url:
>> example url:
>> links displayed when a document query was executed in the portal.
>> Sarah Knoop wrote:
>>> Hi Frank,
>>> set to true when you execute the query. Thus you only get back the
>>> list of references to document metadata instead of the whole
>>> DocumentEntry object that will contain the URL or document uniqueID
>>> that you need to do the retrieve.
>>> hope this helps,
>>> Sarah
>>>> debug messages like "Found 193 object references". I also see a
>>>> dump of the RegistryObjectList xml. I do not see any errors in the
>>>> logs.
>>>> I call response.getReferences(), the EList contains 193 entries.
>>>> I'm unable to retrieve any documents.
>>>> Sarah Knoop wrote:
>>>>> hi Frank,
>>>>> a few documents. Note ... that there is no assigning authority name
>>>>> in the registered id:
>>>>> hope this helps,
>>>>> - Sarah
>>>>>> patientid - 139158
>>>>>> registry url -
>>>>>> returned.
>>>>>> Thanks,
>>>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #44869 is a reply to message #44758] Thu, 24 July 2008 17:42 Go to previous message
Frank,
I sent you a keystore and truststore that'll work for retrieve from
https://lswin10.dfw.ibm.com:9444. We can't do anything about the oracle
one...looks like a submission from a previous testing session for HIMSS
and the server is no longer available.
-Matt
> 1) unknown host
> example url:
> example url:
> Sarah Knoop wrote:
>> Hi Frank,
>> do the retrieve.
>> hope this helps,
>> Sarah
>>> Sarah Knoop wrote:
>>>> hi Frank,
>>>> the registered id:
>>>> hope this helps,
>>>> - Sarah
>>>>> patientid - 139158
>>>>> registry url -
>>>>> returned.
>>>>> Thanks,
>>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586183 is a reply to message #44495] Wed, 23 July 2008 19:08 Go to previous message
hi Frank,
registered id:
hope this helps,
- Sarah
> patientid - 139158
> registry url -
> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586232 is a reply to message #44526] Thu, 24 July 2008 11:23 Go to previous message
Sarah Knoop wrote:
> hi Frank,
> registered id:
> hope this helps,
> - Sarah
>> patientid - 139158
>> registry url -
>> Thanks,
>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586242 is a reply to message #44618] Thu, 24 July 2008 12:17 Go to previous message
Hi Frank,
do the retrieve.
hope this helps,
Sarah
> Sarah Knoop wrote:
>> hi Frank,
>> the registered id:
>> the issue.
>> hope this helps,
>> - Sarah
>>> patientid - 139158
>>> registry url -
>>> Thanks,
>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586294 is a reply to message #44648] Thu, 24 July 2008 16:23 Go to previous message
1) unknown host
example url:
example url:
Sarah Knoop wrote:
> Hi Frank,
> do the retrieve.
> hope this helps,
> Sarah
>> Sarah Knoop wrote:
>>> hi Frank,
>>> the registered id:
>>> the issue.
>>> hope this helps,
>>> - Sarah
>>>> patientid - 139158
>>>> registry url -
>>>> Thanks,
>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586316 is a reply to message #44758] Thu, 24 July 2008 17:19 Go to previous message
Hi Frank,
Hope this helps,
- Sarah
> 1) unknown host
> example url:
> example url:
> Sarah Knoop wrote:
>> Hi Frank,
>> do the retrieve.
>> hope this helps,
>> Sarah
>>> Sarah Knoop wrote:
>>>> hi Frank,
>>>> the registered id:
>>>> hope this helps,
>>>> - Sarah
>>>>> patientid - 139158
>>>>> registry url -
>>>>> returned.
>>>>> Thanks,
>>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586326 is a reply to message #44810] Thu, 24 July 2008 17:42 Go to previous message
Sarah Knoop wrote:
> Hi Frank,
> Hope this helps,
> - Sarah
>> as follows
>> 1) unknown host
>> example url:
>> example url:
>> Sarah Knoop wrote:
>>> Hi Frank,
>>> hope this helps,
>>> Sarah
>>>> logs.
>>>> Sarah Knoop wrote:
>>>>> hi Frank,
>>>>> hope this helps,
>>>>> - Sarah
>>>>>> patientid - 139158
>>>>>> registry url -
>>>>>> returned.
>>>>>> Thanks,
>>>>>> Frank
Re: Getting document consumer working with ohf 0.3.0? [message #586338 is a reply to message #44758] Thu, 24 July 2008 17:42 Go to previous message
Frank,
https://lswin10.dfw.ibm.com:9444 We can't do anything about the oracle
-Matt
> 1) unknown host
> example url:
> example url:
> Sarah Knoop wrote:
>> Hi Frank,
>> do the retrieve.
>> hope this helps,
>> Sarah
>>> Sarah Knoop wrote:
>>>> hi Frank,
>>>> the registered id:
>>>> hope this helps,
>>>> - Sarah
>>>>> patientid - 139158
>>>>> registry url -
>>>>> returned.
>>>>> Thanks,
>>>>> Frank
Previous Topic:required runtiime jars?
Next Topic:Availability of IBM testing infrastructure at lswin10.dfw.ibm.com has ended
Current Time: Sun Aug 31 05:32:24 EDT 2025
Powered by FUDForum. Page generated in 0.07030 seconds
