Home » Eclipse Projects » Technology Project and PMC » Can i *lock* a file in CVS
Can i *lock* a file in CVS [message #44492] Mon, 03 February 2003 13:40 Go to next message
Originally posted by: jonathan.brighthaul.com
I've started experimenting with Eclipse and CVS.
From what I gather, when doing an "update" (check in) there is nothing to
prevent other developers
from checking in their version.
Is this true?
If not, how can I enable locking?
Re: Can i *lock* a file in CVS [message #44523 is a reply to message #44492] Mon, 03 February 2003 19:06 Go to previous messageGo to next message
> Is this true?
Since it is possible to lock files in CVS, it isn't very usual. CVS will try
to merge conflicting versions of the files and if it can't do this
operation, it will force a manual merge. Anyway, I THINK this feature -file
locking- is not available through the eclipse ide.
The command-line for locking a file would be:
#> cvs admin -l myfile
Re: Can i *lock* a file in CVS [message #44554 is a reply to message #44492] Mon, 03 February 2003 21:38 Go to previous messageGo to next message
Originally posted by: maildump.pacbell.net
The idea is that you do not lock an entire file to avoid the problem of
having to unlock files should you be running to the store, getting your hair
done or gunned down in a drive-by. CVS will flag conflicts when two or more
indivduals have updated the same section of code and the frequency of such
collisions is relatively infrequent. Given the sheer number and scope of
projects using CVS as the version control system you can rest assured this
approach is both effective and reliable. I will it mit it does take some
getting use to.
"Yonatan Taub" <jonathan@brighthaul.com> wrote in message
news:b1mbsp$8jv$1@rogue.oti.com...
> Is this true?
Re: Can i *lock* a file in CVS [message #44585 is a reply to message #44492] Tue, 04 February 2003 04:57 Go to previous message
No and believe me it is a good thing, I've been on the exclusive lock route
a few years ago, it causes more problems than it solves issues.
> Is this true?
Avoid it, as somebody said, half the world uses CVS and nobody has a problem
with the non locking approach of CVS, in fact I think it is one of the big
advantages this program has, simply try it and you will love that nobody
has build his own workspace by locking half the project away.
Re: Can i *lock* a file in CVS [message #589759 is a reply to message #44492] Mon, 03 February 2003 19:06 Go to previous message
> Is this true?
Re: Can i *lock* a file in CVS [message #589771 is a reply to message #44492] Mon, 03 February 2003 21:38 Go to previous message
getting use to.
> Is this true?
Re: Can i *lock* a file in CVS [message #589781 is a reply to message #44492] Tue, 04 February 2003 04:57 Go to previous message
> Is this true?
Previous Topic:Can i *lock* a file in CVS
Next Topic:F2 Javadoc doesn't appear
Current Time: Sun Aug 31 00:04:56 EDT 2025
Powered by FUDForum. Page generated in 0.03853 seconds
