Home » Archived » BIRT » External Report Parameters and TimeDate parameters
External Report Parameters and TimeDate parameters [message #44488] Wed, 08 June 2005 09:59 Go to next message
Originally posted by: itsupport.millwood.uk.com
Hi All
Great product.
I am trying to do a couple of things and as I am new to this it is proving
difficult.
I am trying to place a TimeDate parameter into the query. I have
successfully added parameters for the a string property which it then uses
for the query where clause, but when I try to pass through a time date
value, when passing the value from the report parameter to the data set
parameter, it cannot convert the data to a java date object, and gives out a
cast error (e.g. cannot create date object please use this format ......), I
am using the short date format for entering in (e.g. 7/5/05). P.S I am in
the English timedate format.
thanks for any help,
James
Re: External Report Parameters and TimeDate parameters [message #44945 is a reply to message #44488] Fri, 10 June 2005 11:13 Go to previous messageGo to next message
i've had the same issue, but i approached it differently. i made my
parameters in the query portion of type DateTime, and as a default value
put in "new Date()", and that fails when trying to use the default values
in the query. i also bound two user-supplied parameters (of type
DateTime) to the query parameters and the same issue, it can't create a
date. i entered in the dates to use as "01/30/2005 00:00:00 AM" which is
what BIRT/report-designer says to use as date constants, and it still
doesn't work. anyone else have an idea on this?
Re: External Report Parameters and TimeDate parameters [message #45891 is a reply to message #44945] Tue, 14 June 2005 15:08 Go to previous messageGo to next message
You seem to be doing the right thing. If you still can't get the date/time
default parameter value to work, file a Bugzilla report so BIRT engineers
can take a look.
"nate custer" <ncuster3@hotmail.com> wrote in message
news:687f79472db3311edb3b6bc7f32b2a16$1@www.eclipse.org...
Re: External Report Parameters and TimeDate parameters [message #47905 is a reply to message #44945] Sat, 18 June 2005 03:13 Go to previous message
Originally posted by: ejo.USUNo2.pl
I have the same problem
is there any solution for passing date to a sql query ?
Previous Topic:How to count groups ?
Next Topic:Page orientation : Landscae or Portable
Current Time: Sat Jul 26 10:09:12 EDT 2025
Powered by FUDForum. Page generated in 0.06158 seconds
