Home » Eclipse Projects » GEF » Logic Editor Example
Logic Editor Example [message #44423] Thu, 21 November 2002 10:41 Go to next message
Originally posted by: sy_cheung2.yahoo.com
I am using Eclipse 20021119 with GEF build 20021119 and logic editor
20021114, but I can't get that to work.
The logic editor load successfully, but when i click a component (e.g. Or
GATE) and click on the graphics pane, it does not show up.
Do I need a different combination for my setting?
Thanks.
Re: Logic Editor Example [message #44456 is a reply to message #44423] Thu, 21 November 2002 11:10 Go to previous messageGo to next message
Are you trying to create an Or Gate (for example)? I'm not sure what version of
the logic example you were using before, but now it's using drag and drop from
the palette for creation. Drag a component from the palette and drop it on the
editor to create that component.
Eric
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:arislb$8av$1@rogue.oti.com...
> Thanks.
Re: Logic Editor Example [message #44487 is a reply to message #44456] Thu, 21 November 2002 11:14 Go to previous messageGo to next message
Okay, I am going to try that. Does that mean the GEF plugin I develop with
an older version of GEF (0821) will no longer work?
Also why there is an AND gate icon under the Connection icon in the logic
Editor example now? I don't recall I see that in the older version of the
Logic Editor Example.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:ariuak$9ph$1@rogue.oti.com...
version of
from
on the
> Eric
Or
> > Thanks.
Re: Logic Editor Example [message #44517 is a reply to message #44487] Thu, 21 November 2002 11:26 Go to previous messageGo to next message
The other way (using the CreationTool) will still work. The And Gate you're
talking about does this. It's only there for testing purposes.
Eric
news:ariukp$a4k$1@rogue.oti.com...
> version of
> from
> on the
> > Eric
> Or
> > > Thanks.
Re: Logic Editor Example [message #44642 is a reply to message #44517] Thu, 21 November 2002 18:21 Go to previous messageGo to next message
Is it possible to have one creation tool to support both way? The new
Drag-and-drop way and the old "Select and Click" Way
news:ariv9c$akn$1@rogue.oti.com...
you're
> Eric
with
logic
the
> > version of
drop
> > from
it
> > on the
> > > Eric
(e.g.
> > Or
> > > > Thanks.
Re: Logic Editor Example [message #45031 is a reply to message #44642] Fri, 22 November 2002 13:50 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
Isn't this the same question as above?
news:arjnkv$q3d$1@rogue.oti.com...
> you're
> > Eric
> with
> logic
> the
what
> > > version of
> drop
> > > from
drop
> it
> > > on the
> > > > Eric
editor
> (e.g.
> > > Or
> > > > > Thanks.
Previous Topic:GEF version in WSAD 5.0?
Next Topic:LogicNodeEditPolicy
Current Time: Sun Aug 31 20:34:11 EDT 2025
Powered by FUDForum. Page generated in 0.04926 seconds
