Re: How can I foirce a stack trace on a running program within Eclipse [message #46362 is a reply to message #46334] |
Sun, 01 June 2003 23:39  |
Aha- now I get it. I type cntrl-break in the Windows console, not the
Console View.
Peter
"Peter Booth" <pbooth@nocoincidences.com> wrote in message
news:bbeg53$ppo$1@rogue.oti.com...
> I don't think I understand you. I just restarted Eclipse with -consolelog
> and started my application using Run-> When I type a ctrl+break in the
> console view nothing happens.
> This is Eclipse 2.1 on XP with J2SE 1.4.2 beta.
> Peter
> "Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
> news:bb7pnc$sel$1@rogue.oti.com...
> > Are you running Eclipse with the -consolelog option? If you are then the
> > ctrl+break should of worked. This is when running Eclipse.exe. There is
> > no way if you are running through the developement IDE using
> > Runtime-Workbench launch configuration.
> > Rich
FUDForum. Page generated in 0.02924 seconds
