Bigger history repository [message #44405] |
Thu, 31 March 2005 13:29  |
Originally posted by: yoav2005.gmail.com
Is it possible to make Eclipse keep more then one historical copy then one?
I noticed the setting of the number of copies to keep for each file but it
also states then when starting the workbench it will reset. I want to keep
an history of, let's say, the last 14 days, that will be around 20 copies
for each file. possible?
If not. Can anyone recommend on a light weight source safe, that can run
local, and that Eclipse will be able to communicate with?
Thanks.
Re: Bigger history repository [message #47156 is a reply to message #44405] |
Mon, 04 April 2005 17:23  |
Another response explained the Local History preferences, but I want to
warn you that relying on Eclipse's Local History feature instead of a
real source management and versioning system is risky - you're asking
for trouble.
CVS is easy to set up, or you can use a service that will host it for
free/cheap (SourceForge, java.net, FrsehMeat.net, cvsdude.org, etc.).
Trust years of experience that says you'll wish you had it one day.
HTH,
Eric
The early bird may catch the worm, but the second mouse gets the cheese.
FUDForum. Page generated in 0.07659 seconds
