Home » Eclipse Projects » Equinox » which api is usefull for retriving the the project details from with the plugin?
which api is usefull for retriving the the project details from with the plugin? [message #44371] Wed, 30 June 2004 19:39
Originally posted by: salgavkarNOSPAM.NOSPAMyahoo.com
When i select some java source code from the code window, my plugin
should display the project details - such as project name, java source
file name, java class name, and the statement block - of this selected
text. Also note that the selected text may belong to any project.
question: what is the correct way of obtaining the project details from
within the plugin?
i would appreciate any help in this regard, including the pointers to API
that might be of some use.
Thanks.
-salgavkar.
Previous Topic:RCP standalone example
Next Topic:why wont the selectionchanged method work without invokiing tthe plugin?
Current Time: Mon Sep 01 00:34:36 EDT 2025
Powered by FUDForum. Page generated in 0.02828 seconds
