Home » Modeling » GMF (Graphical Modeling Framework) » "Diagram element" dropdown list in gmfgraph Wizard
"Diagram element" dropdown list in gmfgraph Wizard [message #44352] Mon, 11 September 2006 04:56 Go to next message
Hi.
I am not sure about how to use the "Diagram element" dropdown list when
creating a gmfgraph model using the wizard.
Does this specify the diagram root i.e. the canvas, or what?
Thanks for your help.
Felix
Re: "Diagram element" dropdown list in gmfgraph Wizard [message #44539 is a reply to message #44352] Mon, 11 September 2006 06:13 Go to previous message
Originally posted by: lod.staff.civ.org.pl
Basically - yes. It specifies the element that corresponds to the
diagram's canvas.
Set this field before you make any changes in the frame below, since
otherwise the latter will be reset to default.
Mikolaj
> Hi.
> Felix
Previous Topic:Phantom nodes
Next Topic:How to delete shortcut with no element exists instantly when switch editors
Current Time: Tue Jul 22 02:34:20 EDT 2025
Powered by FUDForum. Page generated in 0.06205 seconds
