Home » Eclipse Projects » DTP » Problem with Ecore ODA Data Set wizard
Problem with Ecore ODA Data Set wizard [message #44342] Wed, 07 May 2008 01:55 Go to next message
I have a problem with the new Ecore ODA driver (for Birt).
I have installed all the dependencies and launched a new runtime eclipse.
I get the "Ecore ODA Data Source" item in the New Data Source wizards.
However, I only get the Finished button clickable in the wizard, the Next
button is disabled. I.e. I only get the first wizard page where you can
select which data source type to use. I noticed that this is controlled in
the ODA extension point, but I can't see any problem there.
Do you have any clue what can cause this?
Thanks in advance.
Henrik
Re: Problem with Ecore ODA Data Set wizard [message #44377 is a reply to message #44342] Wed, 07 May 2008 06:46 Go to previous message
Problem solved. A clean workspace did the work...
/Henrik
Re: Problem with Ecore ODA Data Set wizard [message #591104 is a reply to message #44342] Wed, 07 May 2008 06:46 Go to previous message
/Henrik
Previous Topic:Problem with Ecore ODA Data Set wizard
Next Topic:[Ecore ODA Driver] - Joint data set?
Current Time: Sun Aug 31 20:34:05 EDT 2025
Powered by FUDForum. Page generated in 0.04715 seconds
