Home » Archived » XML Schema Definition (XSD) » A question about walkers/visitors
A question about walkers/visitors [message #44318] Wed, 12 May 2004 18:51 Go to next message
Originally posted by: vranganath.sbcglobal.net
I am new to EMF/XSD. I am planning on using XSD to load up a schema
and visit parts of it. However, I could not find a visitor or a
walker that will enable me to do this. So, is there such a class
available in XSD? If so, can you point me to it? If not, is there a
reason for it's absence? Also, how can I contribute one if I do
implement such a class?
waiting for reply,
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: A question about walkers/visitors [message #44350 is a reply to message #44318] Wed, 12 May 2004 19:39 Go to previous messageGo to next message
Venkatesh,
EcoreUtil.getAllContents and/or EObject.eAllContents can be used to walk
the containment tree and the generated XSDSwitch can be used to do
visiting.
Venkatesh Prasad Ranganath wrote:
> waiting for reply,
Re: A question about walkers/visitors [message #45103 is a reply to message #44350] Thu, 20 May 2004 21:38 Go to previous messageGo to next message
Originally posted by: comfortably007numb-python.yahoo.com
Ed Merks wrote:
>Venkatesh,
>visiting.
Thanks for the pointer. However, I have questions about your suggestion.
I looked at the docs for XSDSwitch.doSwitch() says
"The *Switch* for the model's inheritance hierarchy. It supports the
call |doSwitch(object)|
< http://download.eclipse.org/technology/xsd/javadoc/org/eclip se/xsd/util/XSDSwitch.html#doSwitch%28org.eclipse.emf.ecore. EObject%29>
to invoke the |caseXXX| method for each class of the model, starting
with the actual class of the object and proceeding up the inheritance
hierarchy until a non-null result is returned, which is the result of
the switch."
Does this mean it is not a model/instance walker? In other words, given
a object of type X which inherits from Y, the switch will call caseX(),
then caseY(), and so on depending on the return value. If X contains a
reference to an object Z, it will not call caseX() followed by caseZ().
Am I right?
If so, as you suggested I can use TreeIterator to visit the elements
reachable from the root element. The only question is that what is the
ordering of iteration? Is it implicit that if elem1 occurs before elem2
in the container then the TreeIterator will return elem1 before
returning elem2 via next()?
waiting for reply,
- Venkatesh
>>Hi,
>>waiting for reply,
Re: A question about walkers/visitors [message #45163 is a reply to message #45103] Fri, 21 May 2004 10:51 Go to previous message
You're right that a switch is only for a single instance. The switch on
object X won't call caseZ() in your example.
The TreeIterator will do a depth-first traversal of the containment
structure.
This visitor pattern is described in the EMF book (starting on page
337), if you can get your hands on a copy.
Frank.
> Ed Merks wrote:
>> Venkatesh,
>> visiting.
> the switch."
> given a object of type X which inherits from Y, the switch will call
> caseX(), then caseY(), and so on depending on the return value. If X
> contains a reference to an object Z, it will not call caseX() followed
> by caseZ(). Am I right?
> the ordering of iteration? Is it implicit that if elem1 occurs before
> elem2 in the container then the TreeIterator will return elem1 before
> waiting for reply,
> - Venkatesh
>>> Hi,
>>> waiting for reply,
Re: A question about walkers/visitors [message #587039 is a reply to message #44318] Wed, 12 May 2004 19:39 Go to previous message
Venkatesh,
visiting.
> waiting for reply,
Re: A question about walkers/visitors [message #587308 is a reply to message #44350] Thu, 20 May 2004 21:38 Go to previous message
Ed Merks wrote:
>Venkatesh,
>visiting.
the switch."
Am I right?
waiting for reply,
- Venkatesh
>>Hi,
>>waiting for reply,
Re: A question about walkers/visitors [message #587343 is a reply to message #45103] Fri, 21 May 2004 10:51 Go to previous message
structure.
Frank.
> Ed Merks wrote:
>> Venkatesh,
>> visiting.
> the switch."
> waiting for reply,
> - Venkatesh
>>> Hi,
>>> waiting for reply,
Previous Topic:building XSDComplexTypeDefinition programmatically
Next Topic:XSDSchema serialization
Current Time: Sun Aug 31 20:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.07045 seconds
