Home » Eclipse Projects » Technology Project and PMC » using -Xms and -Xmx
using -Xms and -Xmx [message #44309] Sun, 02 February 2003 13:01 Go to next message
Originally posted by: gprego.netvision.net.il
In my application - running on eclipse 2.0.2 I'm getting a
java.lang.outOfMemoryError.
I want to try and use the java flags :
-Xms<size> set initial Java heap size
-Xmx<size> set maximum Java heap size
How should I do it through eclipse project ? and to what values should I
set them ?
Thank's
Re: using -Xms and -Xmx [message #44340 is a reply to message #44309] Sun, 02 February 2003 14:21 Go to previous messageGo to next message
These types of questions are better asked on eclipse.tools but...
you can pass these arguments through to the vm using -vmargs
e.g. -vmArgs -Xmx380M
The values you set them to depend on the specifications of the system you
are working on.
Most of the posts I have seen talk about setting the max heap size to at
least 256M
HTH
Darins
"Lilach " <gprego@netvision.net.il> wrote in message
news:b1jmdi$jri$1@rogue.oti.com...
> set them ?
> Thank's
Re: using -Xms and -Xmx [message #44372 is a reply to message #44309] Sun, 02 February 2003 15:02 Go to previous message
Originally posted by: mkl.inter.net.il
You can specify this kind of options in the launch configuration of your
application. See attached example. Of course, 512M memory is not enough for
every application.
> set them ?
> Thank's
  • Attachment: launch.jpg
    (Size: 76.90KB, Downloaded 505 times)
Re: using -Xms and -Xmx [message #589681 is a reply to message #44309] Sun, 02 February 2003 14:21 Go to previous message
are working on.
least 256M
HTH
Darins
> set them ?
> Thank's
Re: using -Xms and -Xmx [message #589694 is a reply to message #44309] Sun, 02 February 2003 15:02 Go to previous message
every application.
> set them ?
> Thank's
    (Size: 76.90KB, Downloaded 327 times)
Previous Topic:using -Xms and -Xmx
Next Topic:Help regarding toolbar in Eclipse IDE
Current Time: Sun Aug 31 20:33:44 EDT 2025
Powered by FUDForum. Page generated in 0.03884 seconds
