Home » Archived » M2M (model-to-model transformation) » [ATL] Problem with latest run configuration ui
[ATL] Problem with latest run configuration ui [message #44270] Tue, 05 June 2007 03:45 Go to next message
Originally posted by: paul.gribben.gmail.com
I've just refreshed my atl plugins from the CVS repository, and am finding
that the new eclipse run configuration for ATL does not allow me to add
source or target models in the 'ATL Configuration' tab. Is this a bug or
is there a new way to define these?
More information: I've installed the plugins into eclipse 3.2.1, where
previous atl versions have worked fine (last plugin refresh was 6th
april). I have removed all previous atl plugins and run '-clean' on
eclipse.
Paul
Re: [ATL] Problem with latest run configuration ui [message #44424 is a reply to message #44270] Tue, 05 June 2007 04:57 Go to previous message
Paul Gribben schreef:
> finding that the new eclipse run configuration for ATL does not allow me
> to add source or target models in the 'ATL Configuration' tab. Is this a
> bug or is there a new way to define these?
> eclipse.
> Thanks
> Paul
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=181759
The new launch config dialog should automatically detect source and
target model parameters from your transformation module. However, there
are still some issues with the new dialog, mainly concerning cases where
manual definition of input/output models is still necessary.
Dennis
Previous Topic:Dynamic type in ATL rules
Next Topic:Enumeration problem
Current Time: Wed Jul 16 13:01:04 EDT 2025
Powered by FUDForum. Page generated in 0.06648 seconds
