Home » Archived » Visual Editor (VE) » VE S20040624 and Eclipse 3.0: OK
Re: VE S20040624 and Eclipse 3.0: OK [message #44369 is a reply to message #44298] |
Sun, 27 June 2004 20:00   |
Tried VE S20040624 + 3.0 with correct GEF and EMF versions on Linux GTK
and it doesn't work. Instead it exited with this error:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4F7C9202
Function=(null)+0x4F7C9202
Library=/usr/lib/pango/1.4.0/modules/pango-hangul-fc.so
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.pango_layout_get_iter(Native Method)
- locked <0x48b00400> (a java.lang.Class)
at org.eclipse.swt.graphics.TextLayout.getLineBounds(TextLayout .java:490)
org.eclipse.swt.custom.StyledText$ContentWidthCache.contentW idth(StyledText.java:1258)
org.eclipse.swt.custom.StyledText$ContentWidthCache.calculat e(StyledText.java:1221)
org.eclipse.swt.custom.StyledText.calculateContentWidth(Styl edText.java:1920)
at org.eclipse.swt.custom.StyledText.setFont(StyledText.java:67 58)
org.eclipse.ui.texteditor.AbstractTextEditor.setFont(Abstrac tTextEditor.java:2606)
org.eclipse.ui.texteditor.AbstractTextEditor.initializeViewe rFont(AbstractTextEditor.java:2552)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2387)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:275)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.createPart Control(JavaEditor.java:3314)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createPartControl(CompilationUnitEditor.java:1604)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createSplitpaneEditor(JavaVisualEditorPart.java:485 )
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createPartControl(JavaVisualEditorPart.java:436)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:110 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:697)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:686)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:782)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:585)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:573)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2201)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2134)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2126)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2113)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2108)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2091)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard$1.run(NewVisualClassCreationWizard.java:364)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
- locked <0x458ef378> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2572)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2301)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:41 3953136
/opt/sun-jdk-1.4.2.04/bin/java
0804e000-0804f000 rw-p 00005000 03:41 3953136
40000000-40015000 r-xp 00000000 03:02 1650905 /lib/ld-2.3.3.so
40015000-40016000 rw-p 00014000 03:02 1650905 /lib/ld-2.3.3.so
4002a000-40038000 r-xp 00000000 03:02 1650912 /lib/libpthread-0.61.so
40038000-40039000 rw-p 0000d000 03:02 1650912 /lib/libpthread-0.61.so
4003b000-4003d000 r-xp 00000000 03:02 1650909 /lib/libdl-2.3.3.so
4003d000-4003e000 rw-p 00002000 03:02 1650909 /lib/libdl-2.3.3.so
4003e000-40149000 r-xp 00000000 03:02 1650904 /lib/libc-2.3.3.so
40149000-4014c000 rw-p 0010b000 03:02 1650904 /lib/libc-2.3.3.so
40150000-4054b000 r-xp 00000000 03:41 5587437
/opt/sun-jdk-1.4.2.04/jre/lib/i386/client/libjvm.so
4054b000-40566000 rw-p 003fa000 03:41 5587437
4058c000-4059e000 r-xp 00000000 03:02 1650922 /lib/libnsl-2.3.3.so
4059e000-4059f000 rw-p 00011000 03:02 1650922 /lib/libnsl-2.3.3.so
405a1000-405c2000 r-xp 00000000 03:02 1650908 /lib/libm-2.3.3.so
405c2000-405c3000 rw-p 00020000 03:02 1650908 /lib/libm-2.3.3.so
405c3000-405cb000 r-xp 00000000 03:41 5587431
/opt/sun-jdk-1.4.2.04/jre/lib/i386/native_threads/libhpi.so
405cb000-405cc000 rw-p 00007000 03:41 5587431
405df000-405e6000 r-xp 00000000 03:02 1650920
/lib/libnss_compat-2.3.3.so
405e6000-405e7000 rw-p 00006000 03:02 1650920
405e7000-405ef000 r-xp 00000000 03:02 1650923 /lib/libnss_nis-2.3.3.so
405ef000-405f0000 rw-p 00008000 03:02 1650923 /lib/libnss_nis-2.3.3.so
405f0000-405f8000 r-xp 00000000 03:02 1650913 /lib/libnss_files-2.3.3.so
405f8000-405f9000 rw-p 00008000 03:02 1650913 /lib/libnss_files-2.3.3.so
405f9000-405fd000 rw-s 00000000 03:02 1207184 /tmp/hsperfdata_mae/28706
405fd000-4060d000 r-xp 00000000 03:41 5587445
/opt/sun-jdk-1.4.2.04/jre/lib/i386/libverify.so
4060d000-4060f000 rw-p 0000f000 03:41 5587445
4060f000-4062f000 r-xp 00000000 03:41 5587447
/opt/sun-jdk-1.4.2.04/jre/lib/i386/libjava.so
4062f000-40631000 rw-p 0001f000 03:41 5587447
40631000-40645000 r-xp 00000000 03:41 5587450
/opt/sun-jdk-1.4.2.04/jre/lib/i386/libzip.so
40645000-40648000 rw-p 00013000 03:41 5587450
40648000-41fe8000 r--s 00000000 03:41 5588133
/opt/sun-jdk-1.4.2.04/jre/lib/rt.jar
42032000-42048000 r--s 00000000 03:41 5587577
/opt/sun-jdk-1.4.2.04/jre/lib/sunrsasign.jar
42048000-42123000 r--s 00000000 03:41 5587422
/opt/sun-jdk-1.4.2.04/jre/lib/jsse.jar
42123000-42134000 r--s 00000000 03:41 5587578
/opt/sun-jdk-1.4.2.04/jre/lib/jce.jar
42134000-4268d000 r--s 00000000 03:41 5588131
/opt/sun-jdk-1.4.2.04/jre/lib/charsets.jar
44735000-44736000 r-xp 00000000 03:41 32805
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.resources.li nux_3.0.0/os/linux/x86/libcore_2_1_0b.so
44736000-44737000 rw-p 00001000 03:41 32805
4cb47000-4cb63000 r--s 00000000 03:41 5587573
/opt/sun-jdk-1.4.2.04/jre/lib/ext/sunjce_provider.jar
4cb63000-4cb66000 r--s 00000000 03:41 5587574
/opt/sun-jdk-1.4.2.04/jre/lib/ext/dnsns.jar
4cb66000-4cb73000 r--s 00000000 03:41 5587575
/opt/sun-jdk-1.4.2.04/jre/lib/ext/ldapsec.jar
4cb73000-4cc2f000 r--s 00000000 03:41 5587576
/opt/sun-jdk-1.4.2.04/jre/lib/ext/localedata.jar
4cc2f000-4cc34000 r--s 00000000 03:41 413
/mnt/Babe/Apps/eclipse/startup.jar
4ccb5000-4cced000 r--s 00000000 03:41 31
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/core.j ar
4cced000-4ccf5000 r--s 00000000 03:41 32
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/consol e.jar
4ccf5000-4cd01000 r--s 00000000 03:41 30
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/osgi.j ar
4cd01000-4cd17000 r--s 00000000 03:41 34
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/resolv er.jar
4cd17000-4cd2d000 r--s 00000000 03:41 35
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/defaul tAdaptor.jar
4cd2d000-4cd4c000 r--s 00000000 03:41 33
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.osgi_3.0.0/eclips eAdaptor.jar
4ce4e000-4ce5e000 r-xp 00000000 03:41 5587454
/opt/sun-jdk-1.4.2.04/jre/lib/i386/libnet.so
4ce5e000-4ce5f000 rw-p 0000f000 03:41 5587454
4cee3000-4cf3a000 r--s 00000000 03:41 212
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.runtime_3.0. 0/runtime.jar
4cf3a000-4cf40000 r-xp 00000000 03:41 5587457
/opt/sun-jdk-1.4.2.04/jre/lib/i386/libnio.so
4cf40000-4cf41000 rw-p 00005000 03:41 5587457
4cf41000-4cf55000 r--s 00000000 03:41 34058
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.update.configurat or_3.0.0/configurator.jar
4cf55000-4cf6f000 r--s 00000000 03:02 1417240 /tmp/jar_cache63376.tmp
(deleted)
4cf6f000-4d0bd000 r--s 00000000 03:41 18384
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.ide_3.0.0/ide. jar
4d0bd000-4d0d2000 r--s 00000000 03:41 17340
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.runtime.comp atibility_3.0.0/compatibility.jar
4d0d2000-4d0d3000 r--s 00000000 03:41 34054
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.workbench.comp atibility_3.0.0/compatibility.jar
4d0d3000-4d306000 r--s 00000000 03:41 17335
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.workbench_3.0. 0/workbench.jar
4d306000-4d384000 r--s 00000000 03:41 18790
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jface_3.0.0/jface .jar
4d384000-4d397000 r--s 00000000 03:41 17296
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/ws/ gtk/swt-mozilla.jar
4d397000-4d3a4000 r--s 00000000 03:41 17282
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/ws/ gtk/swt-pi.jar
4d3a4000-4d482000 r--s 00000000 03:41 17299
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/ws/ gtk/swt.jar
4d482000-4d483000 r--s 00000000 03:41 33176
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui_3.0.0/ui.jar
4d483000-4d4b9000 r-xp 00000000 03:41 17309
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/os/ linux/x86/libswt-pi-gtk-3062.so
4d4b9000-4d4bb000 rw-p 00035000 03:41 17309
4d4bb000-4d4cb000 r--s 00000000 03:41 18711
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.help_3.0.0/help.j ar
4d4ce000-4d787000 r-xp 00000000 03:02 1916450
/usr/lib/libgtk-x11-2.0.so.0.400.3
4d787000-4d791000 rw-p 002b8000 03:02 1916450
4d794000-4d7fe000 r-xp 00000000 03:02 1896971
/usr/lib/libgdk-x11-2.0.so.0.400.3
4d7fe000-4d803000 rw-p 0006a000 03:02 1896971
4d803000-4d81b000 r-xp 00000000 03:02 2473885
/usr/lib/libatk-1.0.so.0.600.1
4d81b000-4d81d000 rw-p 00017000 03:02 2473885
4d81d000-4d831000 r-xp 00000000 03:02 1703154
/usr/lib/libgdk_pixbuf-2.0.so.0.400.3
4d831000-4d832000 rw-p 00013000 03:02 1703154
4d832000-4d836000 r-xp 00000000 03:02 1871062
/usr/lib/libpangoxft-1.0.so.0.399.1
4d836000-4d837000 rw-p 00003000 03:02 1871062
4d837000-4d841000 r-xp 00000000 03:02 1716282
/usr/lib/libpangox-1.0.so.0.399.1
4d841000-4d842000 rw-p 0000a000 03:02 1716282
4d842000-4d871000 r-xp 00000000 03:02 2558483
/usr/lib/libpango-1.0.so.0.399.1
4d871000-4d876000 rw-p 0002e000 03:02 2558483
4d876000-4d8ad000 r-xp 00000000 03:02 1650956
/usr/lib/libgobject-2.0.so.0.400.1
4d8ad000-4d8af000 rw-p 00036000 03:02 1650956
4d8af000-4d8b2000 r-xp 00000000 03:02 1650960
/usr/lib/libgmodule-2.0.so.0.400.1
4d8b2000-4d8b3000 rw-p 00002000 03:02 1650960
4d8b3000-4d8b7000 r-xp 00000000 03:02 1650962
/usr/lib/libgthread-2.0.so.0.400.1
4d8b7000-4d8b8000 rw-p 00003000 03:02 1650962
4d8b8000-4d935000 r-xp 00000000 03:02 87531
/usr/lib/libglib-2.0.so.0.400.1
4d935000-4d936000 rw-p 0007d000 03:02 87531
4d936000-4d93b000 r-xp 00000000 03:02 197477
/usr/X11R6/lib/libXtst.so.6.1
4d93b000-4d93c000 rw-p 00004000 03:02 197477
4d93c000-4da03000 r-xp 00000000 03:02 197414
/usr/X11R6/lib/libX11.so.6.2
4da03000-4da06000 rw-p 000c6000 03:02 197414
4da06000-4da09000 r-xp 00000000 03:02 197695
/usr/X11R6/lib/libXrandr.so.2.0
4da09000-4da0a000 rw-p 00002000 03:02 197695
4da0a000-4da11000 r-xp 00000000 03:02 197473
/usr/X11R6/lib/libXi.so.6.0
4da11000-4da12000 rw-p 00006000 03:02 197473
4da12000-4da14000 r-xp 00000000 03:02 197671
/usr/X11R6/lib/libXinerama.so.1.0
4da14000-4da15000 rw-p 00001000 03:02 197671
4da15000-4da24000 r-xp 00000000 03:02 197427
/usr/X11R6/lib/libXext.so.6.4
4da24000-4da25000 rw-p 0000e000 03:02 197427
4da25000-4da38000 r-xp 00000000 03:02 197681
/usr/X11R6/lib/libXft.so.2.1.2
4da38000-4da39000 rw-p 00012000 03:02 197681
4da39000-4daa1000 r-xp 00000000 03:02 86736
/usr/lib/libfreetype.so.6.3.4
4daa1000-4daa8000 rw-p 00068000 03:02 86736
4daa8000-4dacf000 r-xp 00000000 03:02 401324
/usr/lib/libfontconfig.so.1.0.4
4dacf000-4dad2000 rw-p 00026000 03:02 401324
4dad3000-4dadc000 r-xp 00000000 03:02 197707
/usr/X11R6/lib/libXcursor.so.1.0.2
4dadc000-4dadd000 rw-p 00008000 03:02 197707
4dadd000-4dae4000 r-xp 00000000 03:02 197675
/usr/X11R6/lib/libXrender.so.1.2.2
4dae4000-4dae5000 rw-p 00006000 03:02 197675
4dae5000-4db09000 r-xp 00000000 03:02 1916625
/usr/lib/libpangoft2-1.0.so.0.399.1
4db09000-4db0a000 rw-p 00023000 03:02 1916625
4db0a000-4db2e000 r-xp 00000000 03:02 296237 /usr/lib/libexpat.so.0.5.0
4db2e000-4db30000 rw-p 00024000 03:02 296237 /usr/lib/libexpat.so.0.5.0
4db30000-4db40000 r-xp 00000000 03:02 554958 /lib/libz.so.1.2.1
4db40000-4db41000 rw-p 0000f000 03:02 554958 /lib/libz.so.1.2.1
4db41000-4db43000 r-xp 00000000 03:02 196097
/usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
4db43000-4db44000 rw-p 00001000 03:02 196097
4db44000-4db4a000 r--s 00000000 03:02 92626
/usr/lib/gconv/gconv-modules.cache
4db4a000-4db4c000 r-xp 00000000 03:02 1650241
/usr/lib/gconv/ISO8859-1.so
4db4c000-4db4d000 rw-p 00001000 03:02 1650241
4db4d000-4db73000 r-xp 00000000 03:41 17308
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/os/ linux/x86/libswt-gtk-3062.so
4db73000-4db75000 rw-p 00026000 03:41 17308
4db75000-4db7c000 r-xp 00000000 03:02 1880851
/usr/lib/gtk-2.0/2.4.0/engines/libthinice.so
4db7c000-4db7d000 rw-p 00007000 03:02 1880851
4db7d000-4db81000 r-xp 00000000 03:02 1838405
/usr/lib/gtk-2.0/2.4.0/engines/libredmond95.so
4db81000-4db82000 rw-p 00003000 03:02 1838405
4db82000-4dbe2000 rw-s 00000000 00:06 46399528 /SYSV00000000 (deleted)
4dbe2000-4dc80000 r--s 00000000 03:41 32813
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.resources_3. 0.0/resources.jar
4dc80000-4dcac000 r--s 00000000 03:41 33956
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.core_3.0.0/t eam.jar
4dcac000-4df79000 r--s 00000000 03:41 18522
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.core_3.0.0/jd tcore.jar
4df79000-4dfa3000 r--s 00000000 03:41 33437
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.text_3.0.0/text.j ar
4e0a5000-4e0d2000 r--s 00000000 03:41 33100
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.launching_3.0 .0/launching.jar
4e0d2000-4e10a000 r--s 00000000 03:41 32807
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.debug.core_3.0.0/ dtcore.jar
4e20c000-4e27d000 r--s 00000000 03:41 33660
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.cvs.core_3.0 .0/cvs.jar
4e27d000-4e27f000 r-xp 00000000 03:02 1697679
/usr/lib/pango/1.4.0/modules/pango-basic-fc.so
4e27f000-4e280000 rw-p 00001000 03:02 1697679
4e291000-4e298000 r-xp 00000000 03:41 17311
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.swt.gtk_3.0.0/os/ linux/x86/libswt-atk-gtk-3062.so
4e298000-4e299000 rw-p 00007000 03:41 17311
4e299000-4e2b1000 r--s 00000000 03:41 34049
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ltk.core.refactor ing_3.0.0/refcore.jar
4e2b1000-4e2bd000 r--s 00000000 03:41 17324
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.filebuffers_ 3.0.0/filebuffers.jar
4e2bd000-4e2dd000 r--s 00000000 03:41 18560
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ltk.ui.refactorin g_3.0.0/refui.jar
4e2dd000-4e2ea000 r--s 00000000 03:41 18378
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.core.expressions_ 3.0.0/expressions.jar
4e2ea000-4e2f7000 r--s 00000000 03:41 33012
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.0 .0/cvsssh2.jar
4e400000-4e916000 r--s 00000000 03:41 16413
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.ui_3.0.0/jdt. jar
4e916000-4e9ad000 r--s 00000000 03:41 18722
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jface.text_3.0.0/ jfacetext.jar
4e9ad000-4e9eb000 r--s 00000000 03:41 33886
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.editors_3.0.0/ editors.jar
4e9eb000-4ea48000 r--s 00000000 03:41 33962
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.workbench.text editor_3.0.0/texteditor.jar
4ea48000-4ea56000 r--s 00000000 03:41 17356
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.views_3.0.0/vi ews.jar
4ea56000-4eab6000 r--s 00000000 03:41 33048
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.search_3.0.0/sear ch.jar
4eab6000-4eb96000 r--s 00000000 03:41 52
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.debug.ui_3.0.0/dt ui.jar
4eb96000-4ebb0000 r--s 00000000 03:41 18502
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.externaltools_ 3.0.0/externaltools.jar
4ebb0000-4ec10000 rw-s 00000000 00:06 46432297 /SYSV00000000 (deleted)
4ec10000-4ed07000 r--s 00000000 03:41 33353
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.cvs.ui_3.0.0 /teamcvsui.jar
4ed88000-4edf9000 r--s 00000000 03:41 33711
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.ui_3.0.0/tea mui.jar
4edf9000-4ee5a000 r--s 00000000 03:41 18728
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.compare_3.0.0/com pare.jar
4ef5c000-4ef6a000 r--s 00000000 03:41 33106
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ui.console_3.0.0/ console.jar
4efeb000-4eff1000 r--s 00000000 03:41 16
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.update.scheduler_ 3.0.0/scheduler.jar
4eff1000-4f00a000 r--s 00000000 03:41 33013
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.0 .0/jsch-0.1.16.jar
4f00a000-4f01a000 r--p 00000000 03:41 6017843
/usr/share/fonts/TTF/VeraIt.ttf
4f029000-4f039000 r--s 00000000 03:41 34936
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.cde_1.0.0/cdm. jar
4f03c000-4f040000 r-xp 00000000 03:02 1650906 /lib/libnss_dns-2.3.3.so
4f040000-4f041000 rw-p 00003000 03:02 1650906 /lib/libnss_dns-2.3.3.so
4f041000-4f050000 r-xp 00000000 03:02 1650914 /lib/libresolv-2.3.3.so
4f050000-4f051000 rw-p 0000e000 03:02 1650914 /lib/libresolv-2.3.3.so
4f0d4000-4f156000 r--s 00000000 03:41 34675
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.java.core_1.0. 0/core.jar
4f156000-4f1ee000 r--s 00000000 03:41 34674
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.java.core_1.0. 0/codegen.jar
4f1ee000-4f1ef000 r--s 00000000 03:41 34676
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.java.core_1.0. 0/common.jar
4f1ef000-4f26c000 r--s 00000000 03:41 34935
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.cde_1.0.0/cde. jar
4f26c000-4f2e8000 r--s 00000000 03:41 35010
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.jfc_1.0.0/jfc. jar
4f2e8000-4f2e9000 r--s 00000000 03:41 35011
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.jfc_1.0.0/jfcc ommon.jar
4f2e9000-4f2f8000 r--s 00000000 03:41 35009
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.jfc_1.0.0/jfcc odegen.jar
4f2f8000-4f30a000 r--s 00000000 03:41 35346
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/p roxy.jar
4f30a000-4f30c000 r--s 00000000 03:41 35342
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/p roxycommon.jar
4f30c000-4f31a000 r--s 00000000 03:41 35343
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/i nitparser.jar
4f31a000-4f346000 r--s 00000000 03:41 35341
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/p roxyremote.jar
4f346000-4f34b000 r--s 00000000 03:41 35340
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/r emotecommon.jar
4f34b000-4f35f000 r--s 00000000 03:41 35347
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.proxy_1.0.0/p roxyide.jar
4f35f000-4f376000 r--s 00000000 03:41 34277
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.emf.codegen_2.0.0 /runtime/codegen.jar
4f376000-4f394000 r--s 00000000 03:41 34322
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.emf.common_2.0.0/ runtime/common.jar
4f394000-4f39b000 r--s 00000000 03:41 34843
/mnt/Babe/Apps/eclipse/plugins/com.ibm.wtp.common.util_1.0.0 /util.jar
4f39b000-4f46f000 r--s 00000000 03:41 34625
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.gef_3.0.0/gef.jar
4f46f000-4f480000 r--s 00000000 03:41 35002
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.ve.propertysheet_ 1.0.0/propertysheet.jar
4f480000-4f52a000 r--s 00000000 03:41 34315
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.emf.ecore_2.0.0/r untime/ecore.jar
4f52a000-4f60c000 r--s 00000000 03:41 250
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.debug.ui_3.0. 0/jdiui.jar
4f60c000-4f618000 r--s 00000000 03:41 18496
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.debug_3.0.0/j di.jar
4f618000-4f6c3000 r--s 00000000 03:41 18495
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jdt.debug_3.0.0/j dimodel.jar
4f6c3000-4f72f000 r--s 00000000 03:41 34639
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.draw2d_3.0.0/draw 2d.jar
4f72f000-4f74a000 r--s 00000000 03:41 35358
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem_1.0.0/javains t.jar
4f74a000-4f76c000 r--s 00000000 03:41 35357
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem_1.0.0/mofjava .jar
4f76c000-4f798000 r--s 00000000 03:41 35332
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.beaninfo_1.0. 0/beaninfo.jar
4f798000-4f7a5000 r--s 00000000 03:41 34653
/mnt/Babe/Apps/eclipse/plugins/com.ibm.wtp.emf.workbench_1.0 .0/emfworkbench.jar
4f7a5000-4f7b4000 r--s 00000000 03:41 34837
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.jem.workbench_1.0 .0/workbench.jar
4f7c4000-4f7c7000 r-xp 00000000 03:02 1916692
/usr/lib/pango/1.4.0/modules/pango-arabic-fc.so
4f7c7000-4f7c8000 rw-p 00002000 03:02 1916692
4f7c8000-4f7ca000 r-xp 00000000 03:02 1916693
4f7ca000-4f7cb000 rw-p 00002000 03:02 1916693
4f7cb000-4f7e7000 r--s 00000000 03:41 34252
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.0 .0/runtime/ecore.xmi.jar
4f7e7000-4f7f4000 r--p 00000000 03:41 6017847
/usr/share/fonts/TTF/VeraMono.ttf
4f80f000-4f832000 r--p 00000000 03:41 6034146
/usr/share/fonts/corefonts/verdana.ttf
4f87c000-4f896000 r--p 00000000 03:41 6029465
/usr/share/fonts/corefonts/andalemo.ttf
4f97b000-4f9e3000 r--s 00000000 03:41 16397
/mnt/Babe/Apps/eclipse/plugins/org.eclipse.pde.core_3.0.0/pd ecore.jar
4f9f1000-4f9ff000 r--p 00000000 03:41 6017844
/usr/share/fonts/TTF/VeraMoBI.ttf
4f9ff000-4facb000 r--p 00000000 03:41 6048814
/usr/share/fonts/unifont/unifont-f.pcf.gz
Heap at VM Abort:
Heap
def new generation total 1984K, used 717K [0x44740000, 0x44960000,
0x44c20000)
eden space 1792K, 32% used [0x44740000, 0x447d3418, 0x44900000)
from space 192K, 67% used [0x44900000, 0x44920380, 0x44930000)
to space 192K, 0% used [0x44930000, 0x44930000, 0x44960000)
tenured generation total 25276K, used 20674K [0x44c20000, 0x464cf000,
0x48740000)
the space 25276K, 81% used [0x44c20000, 0x46050ba8, 0x46050c00,
0x464cf000)
compacting perm gen total 28672K, used 28482K [0x48740000, 0x4a340000,
0x4c740000)
the space 28672K, 99% used [0x48740000, 0x4a3108a8, 0x4a310a00,
0x4a340000)
Local Time = Sun Jun 27 19:59:36 2004
Elapsed Time = 85
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# An error report file has been saved as hs_err_pid28706.log.
# Please refer to the file for further information.
Rich Kulp wrote:
> Thanks for verifying this. :-)
> Francesc Rosés wrote:
> > Hi!
> > Eclipse 3.0 final release is out! I installed it with VE S20040624
> > and It seems to work!
> > Francesc
Re: VE S20040624 and Eclipse 3.0: OK [message #44662 is a reply to message #44599] |
Mon, 28 June 2004 09:41   |
Jeff Myers wrote:
> Look in the .log file in the .metadata directory in your workspace to
> see if there's any relevant errors. You can also try deleting the
> configuration directory in the eclipse directory (or in your home
> directory if you don't have priviledges to write to eclipse directory)
> and restarting Eclipse.
After yor answer, I reinstalled eclipse 3.0 (with SDK release 3.0,
EMF I200406241017, GEF I20040624, VE S20040624), deleting .metadata
in ~/workspace and ~/.eclipse).
The first time I ran it, VE did not appear, the 2nd time it appeared,
but gave an error trying to open a visual class (see the .log below),
the 3rd time it seems to work without errors.
Here's the .log of the 2nd trial:
!SESSION giu 28, 2004 15:26:17.248
eclipse.buildId=I200406251208
java.version=1.4.2_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
!ENTRY org.eclipse.core.runtime 4 2 giu 28, 2004 15:26:17.248
!MESSAGE An internal error occurred during: "Create Remote VM for Visual
Editor for Java".
!STACK 0
org.eclipse.jdt.launching.sourcelookup.containers.JavaSource LookupParticipant.sourceContainersChanged(JavaSourceLookupPa rticipant.java:146)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.addParticipants(AbstractSourceLookupDirector.java:642)
org.eclipse.jdt.internal.launching.JavaSourceLookupDirector. initializeParticipants(JavaSourceLookupDirector.java:43)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.initializeDefaults(AbstractSourceLookupDirector.java:51 8)
org.eclipse.debug.internal.core.LaunchConfiguration.initiali zeSourceLocator(LaunchConfiguration.java:169)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:568)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:480)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:291)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:223)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$CreateRegistry.run(JavaVisualEditorPart.java: 1327)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.ve.java.core 4 0 giu 28, 2004 15:26:31.973
!MESSAGE Exception thrown.
!STACK 0
I hope this will be useful for the debugging by the developers.
Anyway, thanks for your help.
Re: VE S20040624 and Eclipse 3.0: OK [message #44783 is a reply to message #44399] |
Tue, 29 June 2004 01:00  |
I tried 6/28 release and I got the same previous "pango" error.But after
alot of debugging, it turned out that the problem wasn't with eclipse, but
a specific font I installed under X called unifont. After deleting the
font, eclipse started up correctly everytime and worked flawlessly.
VE Team thanks for the great work.
Mojo wrote:
> Previous error occured when the Visual Editor tries to display a visual
> swing frame class.
> I tried VE S20040624 with the corresponding Eclipse, GEF and VE versions
> as per the release notes and worked flawlessly.
> Hope this helps.
Re: VE S20040624 and Eclipse 3.0: OK [message #592857 is a reply to message #44267] |
Sun, 27 June 2004 10:00  |
> Hi!
> Francesc
Thanks, Rich Kulp
Re: VE S20040624 and Eclipse 3.0: OK [message #592887 is a reply to message #44298] |
Dynamic libraries:
(deleted)
Heap at VM Abort:
Heap
0x44c20000)
0x48740000)
0x464cf000)
0x4c740000)
0x4a340000)
Elapsed Time = 85
> > Hi!
> > Francesc
Re: VE S20040624 and Eclipse 3.0: OK [message #592897 is a reply to message #44369] |
Sun, 27 June 2004 20:08  |
swing frame class.
Hope this helps.
Re: VE S20040624 and Eclipse 3.0: OK [message #592956 is a reply to message #44399] |
Mon, 28 June 2004 08:59  |
I've done the same, but it hangs while loading VE when
I create a Visual Class.
In the progress window it shows 2 tasks:
- Create Remote VM for Visual Editor for Java
|||||||||||________________________________ (task bar at 25%)
Launching Local Proxy VM
- Setup Java Visual Editor
|||||||||||||||____________________________ (task bar at about 33%)
Loading model from source code
I suspect the program conflicts with my environment
configuration (Debian Sarge, X 4.3, Gnome 2.6) or my
eclipse configurations. Anyway, I don't know where to look at to
solve the problem.
Any idea?
Re: VE S20040624 and Eclipse 3.0: OK [message #592981 is a reply to message #44537] |
Mon, 28 June 2004 09:06  |
- Jeff
> solve the problem.
> Any idea?
Re: VE S20040624 and Eclipse 3.0: OK [message #593002 is a reply to message #44599] |
Editor for Java".
!STACK 0
!STACK 0
Re: VE S20040624 and Eclipse 3.0: OK [message #593041 is a reply to message #44399] |
> swing frame class.
> Hope this helps.
Current Time: Wed Jul 16 02:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.08014 seconds
