Home » Archived » Test and Performance Tools Platform (TPTP) » Wish to create own Test Generator
Wish to create own Test Generator [message #44264] Thu, 01 December 2005 09:07 Go to next message
Originally posted by: anthony.marsden.ac.com
I would like to create my own 'Test Generator..' plugin which is available
off the *.recmodel menu list.
Can anyone advise me of how to add my own generator? I've looked around
and found the HTTPRecorder class. But unsure what actually generates the
Java test code.
Any help appreciated.
Kind Regards
Anthony
Re: Wish to create own Test Generator [message #44865 is a reply to message #44264] Mon, 05 December 2005 10:39 Go to previous messageGo to next message
Hi Anthony,
"Test Generation" consists of two steps:
1) converting from the recording file (.recmodel) to a testsuite
2) converting from the testsuite to generated Java code
For #1:
You want to extend the TestGenerator extension point. There is some doc for
this schema in the "org.eclipse.hyades.test.core" plugin, in TPTP 4.0 and
later.
An example of a class which extends TestGenerator is
org.eclipse.hyades.execution.testgen.http.Testgen. This is located (again
in TPTP 4.0 & later) in the org.eclipse.hyades.test.tools.core plugin.
If you wish to create a new testsuite type, also of interest will be the
org.eclipse.hyades.ui.typeDescriptions extension point.
For #2:
Look at the abstract class Generator (in o.e.h.test.tools.core) and the
examples HttpGenerator (in o.e.h.test.ui.core).and PluginJUnitGenerator (in
Note the the Java code is generated through JET templates. The eclipse.org
site has some useful docs & tutorials describing JET.
Hope this helps.
"Anthony Marsden" <anthony.marsden@ac.com> wrote in message
news:6192e4fdacda78f0192832beb37e00ee$1@www.eclipse.org...
> Java test code.
> Kind Regards
> Anthony
Re: Wish to create own Test Generator [message #44893 is a reply to message #44865] Mon, 05 December 2005 12:29 Go to previous message
Originally posted by: akuhn.arcor.de
Hi Anthony,
also check this news post, that i wrote some months ago...
news://news.eclipse.org:119/d319d5$gll$1@news.eclipse.org
Andi
Jeff Nevicosi wrote:
> Hi Anthony,
> For #1:
> later.
> For #2:
> Hope this helps.
>>Hi,
>>Java test code.
>>Kind Regards
>>Anthony
Previous Topic:TPTPExecutionPlugin.zip corrupt
Next Topic:How to write a profiling backend for the TPTP 4.1 AC?
Current Time: Sun Aug 31 04:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.03131 seconds
