Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EContentAdapter behaviour ?
EContentAdapter behaviour ? [message #44248] Thu, 10 August 2006 08:44 Go to next message
I have three model objects (A, B and C) in a GEF Editor.
B has child C added to it. At this point B has and eContentAdapter added
to it.
I now want to add B as a child to A. I add another eContentAdapter to A.
Do I need to remove B's eContentAdapter before I add B to A?
Thanks in advance.
Mark Robinson
Re: EContentAdapter behaviour ? [message #44280 is a reply to message #44248] Thu, 10 August 2006 09:01 Go to previous messageGo to next message
Hi, Mark,
This question would be more appropriate in the eclipse.tools.emf newsgroup,
but I'll try to answer.
If the EContentAdapter that is on A is the *same instance* as the
EContentAdapter that is on B, then you don't need to worry, because it will
detect that it is already attached to B when you add B to A.
If it is not the same instance, then you want to make sure that it is,
otherwise you'll have to ensure that the one adapter is removed from B and
all of its contents (recursively) to avoid replication of adapters.
HTH,
Christian
> to it.
> Thanks in advance.
> Mark Robinson
Re: EContentAdapter behaviour ? [message #44311 is a reply to message #44248] Thu, 10 August 2006 09:09 Go to previous messageGo to next message
--------------050800040600080904020909
Mark,
The content adapter doesn't check whether it's already attached and will
attach itself to all the children automatically, so unless you
specialize this method
protected void addAdapter(Notifier notifier)
notifier.eAdapters().add(this);
to look like this
List eAdapters = notifier.eAdapters();
if (!eAdapters.contains(this))
eAdapters.add(this);
I suspect you'll end up with B having the adapter attached twice (which
is probably what you've noticed and why you are asking).
Are A, B, and C in a resource such that you could attach the adapter to
the resource instead?
> added to it.
> A. Do I need to remove B's eContentAdapter before I add B to A?
> Thanks in advance.
> Mark Robinson
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Mark,<br>
<br>
will attach itself to all the children automatically, so unless you
specialize this method<br>
<blockquote><small>
Re: EContentAdapter behaviour ? [message #44368 is a reply to message #44311] Thu, 10 August 2006 09:12 Go to previous messageGo to next message
Hi, Ed,
This must be what the content adapters I have worked with in the past did
for themselves. Thanks for the correction!
cW
Ed Merks wrote:
> Mark,
> to look like this
>> added to it.
>> Thanks in advance.
>> Mark Robinson
Re: EContentAdapter behaviour ? [message #44830 is a reply to message #44368] Fri, 11 August 2006 04:40 Go to previous message
Many thanks guys.
Leaving the old adapter on the child was causing strange knock on effects
(eg figures not displaying properly). I resolved the problems by removing
the adapter on the source/child before adding it to the target/parent,
and adding a new adapter to parent.
I'm not sure if I can attach the adapter to a resource. Our model is kind
of complicated with a lot of references to objects in different ecore
files. I'll look into that later.
Thanks again.
Christian W. Damus wrote:
> Hi, Ed,
> cW
> Ed Merks wrote:
>> Mark,
>> to look like this
>>> added to it.
>>> Thanks in advance.
>>> Mark Robinson
Re: EContentAdapter behaviour ? [message #584975 is a reply to message #44248] Thu, 10 August 2006 09:01 Go to previous message
Hi, Mark,
HTH,
Christian
> to it.
> Thanks in advance.
> Mark Robinson
Re: EContentAdapter behaviour ? [message #584990 is a reply to message #44248] Thu, 10 August 2006 09:09 Go to previous message
Mark,
to look like this
> added to it.
> Thanks in advance.
> Mark Robinson
<html>
<head>
<title></title>
</head>
Mark,<br>
<br>
<blockquote><small>
Re: EContentAdapter behaviour ? [message #585022 is a reply to message #44311] Thu, 10 August 2006 09:12 Go to previous message
Hi, Ed,
cW
Ed Merks wrote:
> Mark,
> to look like this
>> added to it.
>> Thanks in advance.
>> Mark Robinson
Re: EContentAdapter behaviour ? [message #585277 is a reply to message #44368] Fri, 11 August 2006 04:40 Go to previous message
Many thanks guys.
Thanks again.
> Hi, Ed,
> cW
> Ed Merks wrote:
>> Mark,
>> to look like this
>>> added to it.
>>> Thanks in advance.
>>> Mark Robinson
Previous Topic:CDO committed to CVS
Next Topic:Accessing a Container via OCL
Current Time: Mon Jul 07 12:01:05 EDT 2025
Powered by FUDForum. Page generated in 0.05022 seconds
