EContentAdapter behaviour ? [message #44248] |
Thu, 10 August 2006 08:44  |
I have three model objects (A, B and C) in a GEF Editor.
B has child C added to it. At this point B has and eContentAdapter added
to it.
I now want to add B as a child to A. I add another eContentAdapter to A.
Do I need to remove B's eContentAdapter before I add B to A?
Thanks in advance.
Mark Robinson
Re: EContentAdapter behaviour ? [message #44280 is a reply to message #44248] |
Thu, 10 August 2006 09:01   |
Hi, Mark,
This question would be more appropriate in the eclipse.tools.emf newsgroup,
but I'll try to answer.
If the EContentAdapter that is on A is the *same instance* as the
EContentAdapter that is on B, then you don't need to worry, because it will
detect that it is already attached to B when you add B to A.
If it is not the same instance, then you want to make sure that it is,
otherwise you'll have to ensure that the one adapter is removed from B and
all of its contents (recursively) to avoid replication of adapters.
HTH,
Christian
> to it.
> Thanks in advance.
> Mark Robinson
Re: EContentAdapter behaviour ? [message #44830 is a reply to message #44368] |
Fri, 11 August 2006 04:40  |
Many thanks guys.
Leaving the old adapter on the child was causing strange knock on effects
(eg figures not displaying properly). I resolved the problems by removing
the adapter on the source/child before adding it to the target/parent,
and adding a new adapter to parent.
I'm not sure if I can attach the adapter to a resource. Our model is kind
of complicated with a lot of references to objects in different ecore
files. I'll look into that later.
Thanks again.
Christian W. Damus wrote:
> Hi, Ed,
> This must be what the content adapters I have worked with in the past did
> for themselves. Thanks for the correction!
> cW
> Ed Merks wrote:
>> Mark,
>> The content adapter doesn't check whether it's already attached and will
>> attach itself to all the children automatically, so unless you
>> specialize this method
>> protected void addAdapter(Notifier notifier)
>> notifier.eAdapters().add(this);
>> to look like this
>> List eAdapters = notifier.eAdapters();
>> if (!eAdapters.contains(this))
>> eAdapters.add(this);
>> I suspect you'll end up with B having the adapter attached twice (which
>> is probably what you've noticed and why you are asking).
>> Are A, B, and C in a resource such that you could attach the adapter to
>> the resource instead?
>>> added to it.
>>> A. Do I need to remove B's eContentAdapter before I add B to A?
>>> Thanks in advance.
>>> Mark Robinson
Re: EContentAdapter behaviour ? [message #584975 is a reply to message #44248] |
Hi, Mark,
HTH,
Christian
> to it.
> Thanks in advance.
> Mark Robinson
Re: EContentAdapter behaviour ? [message #584990 is a reply to message #44248] |
Thu, 10 August 2006 09:09  |
--------------050800040600080904020909
Mark,
to look like this
> added to it.
> Thanks in advance.
> Mark Robinson
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Mark,<br>
<br>
will attach itself to all the children automatically, so unless you
specialize this method<br>
<blockquote><small>
Re: EContentAdapter behaviour ? [message #585022 is a reply to message #44311] |
Thu, 10 August 2006 09:12  |
Hi, Ed,
cW
Ed Merks wrote:
> Mark,
> to look like this
>> added to it.
>> Thanks in advance.
>> Mark Robinson
Re: EContentAdapter behaviour ? [message #585277 is a reply to message #44368] |
Many thanks guys.
Thanks again.
> Hi, Ed,
> cW
> Ed Merks wrote:
>> Mark,
>> to look like this
>>> added to it.
>>> Thanks in advance.
>>> Mark Robinson
FUDForum. Page generated in 0.05442 seconds
