Home » Modeling » M2T (model-to-text transformation) » problem with 0.9.0 I200804162020
problem with 0.9.0 I200804162020 [message #44230] Fri, 18 April 2008 07:22 Go to next message
With the latest integration build, my java output is uncompilable.
where I should get
public class Connection extends MyResource implements IConnection {
I get
MyReource implements IConnection {
I think this is related to the fix posted for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=206469
as I use <f:replaceAll value="\s+" ...>
which to strip out whitespace
my template is like this
public class <c:get select="$resourceDef/javaInfo/class"/> extends
<f:replaceAll value="\s+" replacement="" regex="true">
<c:choose>
<c:when test="$resourceDef/type = 'MyDefinition' ">MyDefinition</c:when>
<c:when test="$resourceDef/type = 'MyManager' ">MyManager</c:when>
<c:otherwise>MyResource</c:otherwise>
</c:choose>
</f:replaceAll> implements <c:get
select="$resourceDef/javaInfo/interface"/> {
Re: problem with 0.9.0 I200804162020 [message #44294 is a reply to message #44230] Sat, 19 April 2008 07:19 Go to previous messageGo to next message
Edoardo:
I fixed bug 206469 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=206469).
In tag attributes, JET is supposed to be treating \ as an escape character.
For symetry with the handling of \ in directives, the fix removes the \ and
leaves the following character as a literal even if that character does not
require quoting. I'll take a closer look at how JSP handles this issue and
consider adjusting the behavior.
In the meantime, the easiest work around is to use \\s.
Paul
"Edoardo Comar" <ecomar@uk.ibm.com> wrote in message
news:fua08u$oue$1@build.eclipse.org...
> where I should get
> I get
> <c:choose>
> </c:choose>
Re: problem with 0.9.0 I200804162020 [message #44356 is a reply to message #44294] Mon, 21 April 2008 08:59 Go to previous message
Paul Elder wrote:
> Edoardo:
> Paul
Paul, this is what I did, I don't think you need to change anything -
except that the sample in the HTML reference for the tag needs to be
updated :-)
Previous Topic:is it possible to SORT the results of a jet xpath select ?
Next Topic:Is it possible to retrieve attributes and references from JET using XPath?
Current Time: Thu Jul 17 22:28:18 EDT 2025
Powered by FUDForum. Page generated in 0.09305 seconds
