Home » Eclipse Projects » Remote Application Platform (RAP) » any document for newbie?
any document for newbie? [message #44226] |
Sat, 01 September 2007 07:06  |
Hello everyone,I am new to rap, is there any document for me to get in? Is
there any document introducing how to do it step by step? By the way, I have
tried the rap demo, but I got a Http 400 ERROR, what's this about? Thanks
very much!
Re: any document for newbie? [message #44347 is a reply to message #44284] |
Sat, 01 September 2007 20:02   |
thanks for reply, I made a mistake, it's a http 404 error.
My envioronment is eclipse 3.3 plus rap milestone 6.
And I just import the plugin "org.eclipse.rap.demo" as source project, then
run it as osgi framework.It seem all right for the console output, but when
I visit by http://localhost:9090/rap I got a http 404 error!
"Benjamin Muskalla" <bmuskalla@innoopract.com>
??????:fbcmfu$unh$2@build.eclipse.org...
> Hi!
> We're really sorry to have no real documentation yet. For the first try,
> see http://www.eclipse.org/rap/gettingstarted.php.
> If you've still problems with the HTTP 400 Error code, just tell us what
> you did and maybe we can find the problem together.
> So long
> Benny
>> Is there any document introducing how to do it step by step? By the way,
>> I have tried the rap demo, but I got a Http 400 ERROR, what's this about?
>> Thanks very much!
Re: any document for newbie? [message #44409 is a reply to message #44347] |
Sun, 02 September 2007 08:36   |
did you install the RAP target on top of your existing Eclipse
installation or in a separate folder?
You could start the OSGi launch config with -console and -consolelog to
see if there are any exceptions. Additionally you can use the "ss"
command in the OSGi console to determinate if all bundles were loaded
correctly.
Greets
Benny
>> Hi!
>> So long
>> Benny
>>> Thanks very much!
Re: any document for newbie? [message #44494 is a reply to message #44409] |
Sun, 02 September 2007 10:17   |
I installed rap in a seperate fold and I add the folder to the current
target location then reload, everything is ok,No exception in the
console,the console out put is like this:
osgi> 2007-9-2 22:16:23 org.mortbay.http.HttpServer doStart
??: Version Jetty/5.1.x
2007-9-2 22:16:23 org.mortbay.util.Container start
??: Started org.mortbay.jetty.servlet.ServletHandler@3b1d04
??: Started HttpContext[/,/]
2007-9-2 22:16:23 org.mortbay.http.SocketListener start
??: Started SocketListener on 0.0.0.0:9090
??: Started org.mortbay.http.HttpServer@8c1dd9
??????:fbeasu$phf$1@build.eclipse.org...
> see if there are any exceptions. Additionally you can use the "ss" command
> in the OSGi console to determinate if all bundles were loaded correctly.
> Greets
> Benny
>> then run it as osgi framework.It seem all right for the console output,
>> but when I visit by http://localhost:9090/rap I got a http 404 error!
>>> Hi!
>>> So long
>>> Benny
>>>> way, I have tried the rap demo, but I got a Http 400 ERROR, what's this
>>>> about? Thanks very much!
Re: any document for newbie? [message #44556 is a reply to message #44494] |
Mon, 03 September 2007 06:58   |
Originally posted by: fappel.innoopract.com
as Benjamin already mentioned type ss into the console after you have
started the server. This should display a list of the bundle states. That
could help us to determine what kind problem occured. If you are using IE
deactivate the user friendly or short HTTP error messages in the internet
settings, this may provide a more meaningful problem description.
Ciao
Frank
"Hoping White" <baihaoping@gmail.com> schrieb im Newsbeitrag
news:fbeglc$3n6$1@build.eclipse.org...
>> correctly.
>> Greets
>> Benny
>>>> Hi!
>>>> try, see http://www.eclipse.org/rap/gettingstarted.php.
>>>> what you did and maybe we can find the problem together.
>>>> So long
>>>> Benny
>>>>> in? Is there any document introducing how to do it step by step? By
>>>>> the way, I have tried the rap demo, but I got a Http 400 ERROR, what's
>>>>> this about? Thanks very much!
Re: any document for newbie? [message #44786 is a reply to message #44716] |
Mon, 03 September 2007 10:44  |
for some reasons your launch loads different versions of the same bundles on
startup. For example org.eclipse.equinox.app exists twice - the state of one
version is ACTIVE and the one of the other INSTALLED only. This will
probably cause the problem. You may open the Run Dialog (Run -> Open Run
Dialog), select the launch configuration and goto the tab named Bundles.
Ensure that only one version of each bundle is checked, I would guess the
newest version of each should do.
Ciao
Frank
news:fbh3su$off$1@build.eclipse.org...
> Hello,this is result of "ss":
> Framework is launched.
> id State Bundle
> 0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
> 1 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.20070817-1525
> 2 ACTIVE org.eclipse.core.expressions_3.3.0.v20070606-0010
> 3 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
> 4 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
> 5 ACTIVE org.eclipse.rap.core.databinding.beans_1.0.0.20070817-1525
> 6 ACTIVE org.eclipse.osgi.services_3.1.200.v20070531
> 8 ACTIVE org.eclipse.rap.demo_1.0.0.20070817-1525
> 9 ACTIVE org.eclipse.equinox.http.registry_1.0.0.v20070608
> 10 ACTIVE org.eclipse.rap.jface_1.0.0.20070817-1525
> 11 ACTIVE org.apache.commons.logging_1.0.4.20070817-1525
> 12 ACTIVE org.apache.commons.logging_1.0.4.v200706111724
> 13 INSTALLED org.eclipse.core.expressions_3.3.0.v20070531-1300
> 14 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
> 15 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.20070817-1525
> 16 ACTIVE org.eclipse.rap.demo.databinding_1.0.0.20070817-1525
> 17 ACTIVE org.eclipse.rap.rwt_1.0.0.20070817-1525
> 18 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
> 19 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
> 20 ACTIVE org.mortbay.jetty_5.1.11.v200706111724
> 21 ACTIVE org.eclipse.rap.ui_1.0.0.20070817-1525
> 23 ACTIVE org.mortbay.jetty_5.1.11.20070817-1525
> 24 ACTIVE javax.servlet_2.4.0.20070817-1525
> 25 ACTIVE org.eclipse.rap.core.databinding_1.0.0.20070817-1525
> 26 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.v20070606
> 27 INSTALLED org.eclipse.equinox.http.registry_1.0.0.20070817-1525
> 28 ACTIVE org.eclipse.rap.jface.databinding_1.0.0.20070817-1525
> 29 ACTIVE org.eclipse.equinox.http.jetty_1.0.0.v20070607
> 30 ACTIVE org.eclipse.core.commands_3.3.0.I20070605-0010
> 32 ACTIVE javax.servlet_2.4.0.v200706111738
> 33 ACTIVE org.eclipse.core.commands_3.3.0.I20070523-1500
> 35 ACTIVE org.eclipse.osgi.services_3.1.200.v20070605
> 36 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
> 37 INSTALLED org.eclipse.equinox.app_1.0.0.v20070423
> 38 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
> 40 INSTALLED org.eclipse.equinox.http.jetty_1.0.0.20070817-1525
> when go to http://localhost:9090/rap got this
> HTTP ERROR: 404
> ProxyServlet: /rapRequestURI=/rap
> Powered by Jetty://
> and No other information!
> Thanks very much.
> Oh, by the way, my broswer is IE7 ,is that possible something to do with
> it?
> "Frank Appel" <fappel@innoopract.com>
> д
Current Time: Tue Jul 15 06:36:26 EDT 2025
Powered by FUDForum. Page generated in 0.06304 seconds
