Home » Eclipse Projects » Subversive » Update site broken
Update site broken [message #44220] Sun, 12 April 2009 01:11 Go to next message
I haven't been able to use your update site at:
http://download.eclipse.org/technology/subversive/0.7/update -site/
for a few days now. I can connect to it and the list of features appears to be correct but when I try to install I get
this error:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.team.svn,0.7.7.I20090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.core,0.7.7.I20090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.core.nl1,0.7.7.I20090224-19 00
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn,0.7.7.I20090 224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.help,0.7.7.I20090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.nl1,0.7.7.I20090224-1900
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1,0.7.7.I2 0090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.resource.ignore.rules.jdt,0 .7.7.I20090224-1900
org.eclipse.update.feature,org.eclipse.team.svn.resource.ign ore.rules.jdt,0.7.7.I20090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui,0.7.7.I20090224-1900
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui.nl1,0.7.7.I20090224-1900
The latest archived site works OK.
I'm using Eclipse 3.5, I20090407-1430.
Thomas Hallgren
Re: Update site broken [message #44375 is a reply to message #44220] Mon, 13 April 2009 05:14 Go to previous messageGo to next message
Hello Thomas,
Probably, there were problems with download server, I just checked it with
Eclipse 3.5 and it works.
> to be correct but when I try to install I get this error:
> Thomas Hallgren
Re: Update site broken [message #44435 is a reply to message #44375] Mon, 13 April 2009 08:31 Go to previous message
Originally posted by: igor.ifedorenko.com
This is more likely a bug in P2. I've seen this problem installing
several plugins and in all cases the problem goes away if I resintall
everything clean.
Igor
Igor Burilo wrote:
> Hello Thomas,
>> Regards,
>> Thomas Hallgren
Previous Topic:SVN 1.6 support
Next Topic:Subversive ready for Ganymede?
Current Time: Fri Jul 11 21:40:00 EDT 2025
Powered by FUDForum. Page generated in 0.25363 seconds
